TTL
Does anyone know if the basic stamp can talk to a TTL device and if socould you give me a snippet code example and a tip on how the example isconnected (use of resistors etc.)?
Wayne Fulcher
wayne@ddinet.com
Wayne Fulcher
wayne@ddinet.com
you
> give me a snippet code example and a tip on how the example is connected (use
of
> resistors etc.)?
TTL refers to the voltage levels used to represent logic 0 and 1 (0 and 5
VDC). The Stamps use these same voltage levels, so you can connect the 2
directly together.
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: (403)-730-8603 Fax: (403)-730-8903
See our NEW BASIC Stamp Prototyping tools !
http://www.hvwtech.com/stampstack.htm
The device has a Data Out Pin and a Clock In Pin.
Could you please give me an example of how to read data from the device?
Wayne Fulcher
wayne@d...
From: Mark Hillier [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=sgqlUg5_xONxzAjszj5B4xnrOieY5D-Eyy4dKxi2m6E6CJdtO2Onfd3WWHrcS4N3U-ASp43wR6UQ]Mark@H...[/url
Sent: Thursday, June 28, 2001 4:12 PM
Subject: Re: [noparse][[/noparse]basicstamps] TTL
could you
(use of
> resistors etc.)?
directly together.
from the same email address that you subscribed with. Text in the Subject
What sort of device are you using? Is it an IC with
identifying information? Do you have a data sheet? Or
is it a device like a transducer, which gives an
analog signal that must be converted to serial digital
data by an ADC for the Stamp to deal with. I was ready
to send some code samples, but realized that I may be
answering the wrong question, so we should define the
device to be read first.
Bob Pence
--- Wayne Fulcher <wayne@d...> wrote:
> Thanks but what command do I use to read the data.
> Thanks,
> Wayne Fulcher
> wayne@d...
> From: Mark Hillier [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KphvSmboWs5RUDKIN4XtF6v_TGf8dNRHQ6IYzr6Uy4OSu0RaQQj0Ov_noEyhNFkgA920R1O2aUw]Mark@H...[/url
> could you
> (use of
> > resistors etc.)?
> directly together.
> Neat Stuff
> with. Text in the Subject and Body of the message
> will be ignored.
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail
http://personal.mail.yahoo.com/
The SHIFTOUT example on page 316 show how to write data to a 74HC595. This
is a typical example of how you would communicate with a device having a
Data In pin and a Clock pin. In your application, you would use the SHIFTIN
command.
Lots of older TTL devices like the 74LS164 and 74LS165 that have been used
by Stamp users for years.
Good Luck!
>Thanks,
>Wayne Fulcher
>wayne@d...
>From: Mark Hillier [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=J7JYoQSk84eOPH8JXyj67ZBg1UNjndRwxxlLDlrg7nbWIbPz2RPjmnWDOIvFrdhL_3rxqUjBQSqA]Mark@H...[/url
>could you
>(use of
> > resistors etc.)?
>directly together.
Mike Walsh
walsh@i...
or 5. To the Stamp, signals below about 1.4 vdc are
logical 0 and above are logical 1. But if I interface
directly to my 250-psi range transducer, which
produces TTL voltage, I can only read whether I am
above or below about 53 psig. Natch, I hook the signal
up to a 3-pin serial ADC, and I have lots more
information.
> TTL device and if so could you
> the example is connected (use of
> > resistors etc.)?
> directly together.
> Neat Stuff
> will be ignored.
Do You Yahoo!?
The dartboard has a switch matrix of (19 pins) 11 X 8 = 88 possibilities.
The card has two - 20 pin chips on it, which reads the switch matrix and has
a 6 pin (RJ45) port to interface with.
The pin outs are as follows:
1 - Ground
2 - Ground
3 - +5v
4 - Data (Out from dartboard)
5 - Clock (In to Dartboard)
6 - Ground
I don't have the board with me this second or I would try to tell you what
type of chips those are. (If it mattered).
Wayne Fulcher
wayne@d...
From: Pence Bob [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rsAWzifqZt6NNh7G67iUBJk4H5zcReqlcv1VkXlcdnKvWaoeWiED3u-0pRKEZfUGwgQfck1AuULTgZArNPbWsw]bobpence_2000@y...[/url
Sent: Thursday, June 28, 2001 4:53 PM
Subject: RE: [noparse][[/noparse]basicstamps] TTL
Wayne -
Bob Pence
> Thanks,
> Wayne Fulcher
> wayne@d...
> From: Mark Hillier [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Ry_Re9oM3gAIgcV2s35GjQahzhMDZeUyBnffKPjS8FOK4NyEeRFqdVVfPOER5IAmvWLyaMKGQwY]Mark@H...[/url
> could you
> (use of
> > resistors etc.)?
> directly together.
> Neat Stuff
> will be ignored.
Do You Yahoo!?
Very helpful explanation for us (digiligently studying at the
same time) newbies.
THANKS!
Ken Ambrose
with enough thrust, pigs fly just fine.
---- On Thu, 28 Jun 2001, Pence Bob (bobpence_2000@y...)
wrote:
> One caveat, TTL refers to 0 _TO_ 5 volts, not always 0
> information.
> > > resistors etc.)?
> > directly together.
> > Neat Stuff
> > will be ignored.
> Do You Yahoo!?
in the
> The card has two - 20 pin chips on it, which reads the switch matrix and has a
6
> pin (RJ45) port to interface with. The pin outs are as follows: 1 - Ground 2 -
> Ground 3 - +5v 4 - Data (Out from dartboard) 5 - Clock (In to Dartboard) 6 -
> Ground
Sounds like a synchronous serial connection; in which case you would use
the SHIFTIN command. See the Stamp Manual for the command syntax and
some good examples.
In essence, you connect one Stamp pin to the Clock pin, and another to the
data pin. The SHIFTIN command toggles the clock line and then looks at the
data line. It repeats this process a number of times (defined by you within
the SHIFTIN command) and collects all the bits. You need 7 bits to
represent decimal 88 so it's likely an 8-bit word that comes out of the
dartboard.
It would seem that there is not a third or forth pin
to deal with, at least not at this connection point.
So connect +5 and grounds, and pick a couple of Stamp
I/O pins for clock and data. The Shiftin command is
your best choice, e.g.:
clk CON 0 ' clock pin
dio CON 1 ' data pin
ad VAR WORD ' analog data
SHIFTIN dio, clk, MSBPOST, [noparse][[/noparse]ad\16]
DEBUG BIN16 ad, CR
Look for any repetition in ad to see if the data is
less than 16 bits wide. The MSBPOST is a guess - a
guess that data follows the clock pulse (versus
MSBPRE, data present on data pin before the clock
pulse), and a guess that data is sent
most-significant-bit first, versus LSBPOST and LSBPRE.
(MSB first implies that the nibble 1010 = 10 decimal,
while LSB first would make it 5 decimal. I'm not used
to thinking of 1010 as 5 and 0101 as 10, but some
devices use this format, known as "big-endian." Most
use the "little-endian" format where the MSB comes
first and the LSB last - the littler part at the end.)
If this doesn't produce sensible results, there is a
more manual approach.
I have an application with TI 'LS674 shift registers
that just didn't come out right using SHIFTIN. So I
built a manual version (I may revisit SHIFTIN or the
delays built into this code, but I maintain that it
just wasn't working out).
i VAR NIB ' counter
HIGH clk
FOR j = 0 TO 15
ad = ad << 1 ' shift left 1 bit,
' implied little-endian
dio = IN1 ' Aside: can anyone do this better?
' So far I am either doing this for
' clarity or using literals like IN1
' in lines like the next one where
' I would much rather use a constant
' or variable.
ad = ad + dio
' pulse clock so that next data bit goes to dio
LOW clk
PAUSE 10 ' milliseconds
HIGH clk
PAUSE 10
NEXT
DEBUG BIN16 ad, CR
Hope this helps. The "<<" above can be replaced by a
">>" if the item ends up being big-endian. I use it
for DIP switches, so big-endian and little-endian
don't matter in my app.
Bob Pence
> Basically the device is a card that is connected to
> a dartboard.
> 1 - Ground
> 2 - Ground
> 3 - +5v
> 6 - Ground
> Thanks,
> Wayne Fulcher
> wayne@d...
> From: Pence Bob [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tCl9H8GtTws79cmn8qtNdbj7-C8mrQB2v91VtbEy3tFkSOL43DPI4qxEExZ_XDT3Fa19DM8VmLc3ysOo4Xt2Ng]bobpence_2000@y...[/url
> Wayne -
> Or
> digital
> ready
> be
> the
> Bob Pence
> > Thanks,
> > Wayne Fulcher
> > wayne@d...
> > From: Mark Hillier [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3TjJhwRFd6jjDPAewBtlaohWUQ0w3foT9FKf8RmpEpqc8-DMN0OoC_QQUhJq8fEjknZGz_vTB1Ec]Mark@H...[/url
> a
> > could you
> > (use of
> > > resistors etc.)?
> > directly together.
> other
> > Neat Stuff
> > will be ignored.
> Do You Yahoo!?
> will be ignored.
Do You Yahoo!?
trying to assign a bit value to a constant, which
tends to work better with variables. Let's pretend
that I used a bit variable instead, or just did ad =
ad + IN1, which brings back up my question in the
comments (viz I can choose which output pin to set
high or low with a variable, constant, or expression
(HIGH pin_number_var), but can I read an input pin
with a variable (ad = ad +
IN(current_shift_register))?
Bob Pence
--- Pence Bob <bobpence_2000@y...> wrote:
> Wayne -
> Stamp
> DEBUG BIN16 ad, CR
> LSBPRE.
> decimal,
> used
> end.)
> i VAR NIB ' counter
> HIGH clk
> FOR j = 0 TO 15
> IN1
> constant
> ' or variable.
> ad = ad + dio
> LOW clk
> HIGH clk
> PAUSE 10
> NEXT
> DEBUG BIN16 ad, CR
> Bob Pence
> to
> > a dartboard.
> X
> > 1 - Ground
> > 2 - Ground
> > 3 - +5v
> > 6 - Ground
> > Thanks,
> > Wayne Fulcher
> > wayne@d...
> > From: Pence Bob [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=c5LyLLIKoAzBZlM1qm0Of-0yZsmBodCFborOVOaJDcoiHP4bnG7cnDRg7Zc2_YTyle93p8OOvCjxgz-QsHnKfTQ5]bobpence_2000@y...[/url
> > Wayne -
> with
> > Or
> > digital
> > ready
> > be
> > the
> > Bob Pence
> data.
> Pin.
> read
> > > Thanks,
> > > Wayne Fulcher
> > > wayne@d...
> > > From: Mark Hillier [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YDTrzS8ic8-VOUsPCTFkHDBek7atla3K6j4AoYqZqp4Ce-Ikgawy98gB-AosLoayQcTUKnpBAxo]Mark@H...[/url
> to
> > a
> > > could you
> how
> > > (use of
> > > > resistors etc.)?
> represent
> so
> > > directly together.
> > other
> > > Neat Stuff
> message
> > > will be ignored.
=== message truncated ===
Do You Yahoo!?
