Range sensor Website
My apologys to everyone. Normally I do leave a source for parts.
I buy my range sensors from Acroname. I am sure there are other sources.
http://www.acroname.com/robotics/parts/c_Sensors.html
I use the GP2D02 sensor $21 that gives a digital range output 10-80cm.
The GP2D05 sensor will give a digital on/off value based upon a distance
threshold you define with its potentiometer (from 10-80Cm) $19 This means
you can set the detector to sense an object that is 30 CM away and it will
send a 1 bit output when anything reaches the 30cm mark. For the $2
differance you may want the GP2D02 sensor and you can use it for other
projects later on.
Each sensor has a basic stamp II program that acroname provides with it.
Another nice sensor for other peoples uses is the new Devontech SRF04 range
sensor available at the same location ($25). This sensor has a range of 3cm
to 3 meters, and will detect a very narrow stick within its beam pattern. I
like it for robotics and detecting narrow chair legs. I have never yet seen
the SRF04 sensor fail to detect anything. Sometimes the GPD202 will not
detect a very small tiny object. Again the chair leg as an example. For
something as large as a hand, the GPD202 would detect that fine.
Please note at 10cm (4 inches) the GP series sensors are at their lower
range of detection limit. Depending on the box size you may have an issue
here. The SRF04 will detect down to 3CM (1 and 1/4 inches) Use the
Sr_sonar_2 section of the basicstamp II program example for this SRF04 sensor.
Sincerely
Kerry
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
projects later on.
Sincerely
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
Thank you very much! I did some searching for "GPR200" on
google and other engines. Didn't have any success. And I had
noticed that a number of other messages recently had
recommended products or sites without providing any leads on
how to contact...
Ken Ambrose
with enough thrust, pigs fly just fine.
---- On Thu, 28 Jun 2001, Kerry Barlow (admin@m...)
parts.
other sources.
output 10-80cm.
a distance
$19 This
> means
away and it
> will
the $2
for other
> projects later on.
provides with it.
Devontech SRF04
> range
a range of
> 3cm
beam
> pattern. I
never yet
> seen
GPD202 will not
example. For
fine.
their lower
have an
> issue
Use the
this SRF04
> sensor.
> Sincerely
> Kerry
> Admin@M...
> Kerry Barlow
> p.o. box 21
> kirkwood ny
> 13795
> from the same email address that you subscribed with. Text
in the
ultrasonic on my big robot, and they work well. Acroname's documentation is
the tops also.
If you want to see something really cool, I've got a Devantech unit mounted
on a servo that will pinpoint an object as small as a pencil at about 5
feet.
> projects later on.
range
3cm
I
seen
sensor.
