Sharp GP2D15 adjustment ?
All,
I would like to increase the detection point on the Sharp IR
sensors from the factory set value of 23cm (~9in) to the maximum of
about 80cm (~31in). I seem to recall reading the procedure for doing
this adjustment, but I am unable locates it now that I need it.
Sharp recommends that I use the GP2D12 but this would require that I
use a comparator and I would prefer to not add additional circuitry.
Can some one please point me to the procedure?
Phil
Phil
moving the frequency either side of 38KHz has a pronounced effect on the
range.
Sid
The GP2D15 is the non-adjustable version of the GP2D05. The GP2D05 has
the comparator built-in and a small pot on the back to adjust the trigger point.
I would think that there is a surface-mount resistor (or 2) on the board that
could, theoretically, be changed to set a new trigger-point but Sharp does
not release info on the component-level of their products.
Depending on what your time is worth to you, you're better-off getting the
GP2D05.
We carry this item as a complete kit with the speacial cable and a mounting
bracket and all hardware -and a manual, of course.
http://www.hvwtech.com/sensors.htm
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: (403)-730-8603 Fax: (403)-730-8903
See our NEW BASIC Stamp Prototyping tools !
http://www.hvwtech.com/stampstack.htm
Acroname, who seems to have pretty good prices and great documentation, not
to mention providing the proper connector and wires. They also carry the
other Sharp modules as well as the Devantech ultrasonic sensor.
GP2D02 -- http://www.acroname.com/robotics/parts/R19-IR02.html
GP2D05 -- http://www.acroname.com/robotics/parts/R21-IR05.html
GP2D12 -- http://www.acroname.com/robotics/parts/R48-IR12.html
GP2D15 -- http://www.acroname.com/robotics/parts/R49-IR15.html
point.
that
> GP2D05.
What would I need to adjust to alter the frequency?
Phil
--- In basicstamps@y..., Newzed@a... wrote:
> You might try adjusting the IR requency. In playing with my own I
found that
on the
> range.
> Sid
According to Sharp, they are no longer producing the D05 and are
selling the D15 as its replacement. (Apparently they had some
manufacturing problems with the D05.) The D15 also does not require
a CLK input as it is self-triggering, which simplifies the
interconnect but means that a method of preventing false triggers
should be implemented.
Thanks for the information,
Phil
N6MWC
of
doing
that I
circuitry.
has
trigger point.
board that
Sharp does
getting the
> GP2D05.
mounting
Actually, the 05 is still available; but they are pushing customers towards
other products by imposing large minimums. We haven't heard about any
manufacturing problems.
We've seen them (even have a few) but we don't carry them because they
can't be adjusted.
