Decoupling capacitor advice
I just built myself an altimeter using the BS2, a MAX187 ADC, a
MPX4115 pressure sensor and a 25LC640 EEPROM for storing the data
(very very similar to the one on Shaun's web page actually).
My question is this: the data I'm getting is very noisy. At the
moment I have no decoupling capacitors in the circuit. Would this
help? (I believe it will). My real question is what value to choose,
and where to put them. The datasheet for the MPX4115 recommends
different values than those recommended for the MAX187 (1.0+0.01uF
and 4.7+0.1uF respectively). So which should I be using? Surely not
all four, two for each IC?
I've also read (on this list) that they should go as close as
possible to the chip I'm trying to decouple. So do I put them next to
the MPX4115 or the MAX187? And how close is close? Is an inch close
enough?
When I get this working well, I'll put it up on a website. Its a
rocket altimeter, and hopefully soon will include an ADXL190
accelerometer (to measure vertical acceleration), one of Analog
Devices' two-axis accelerometers (to measure vibration in the other
two axes), temperature sensors and magnetic field sensors (to measure
the Earth's magnetic field).
Thanks alot, sorry for all the questions.
James.
enough?
James.
from and that, ideally, would be the best place for the caps. Anything
short of this is a walk in the dark. My experience would tell me that
one inch is close enough. Where the power comes on to the board might
be a good place to start. The reason for two different sizes is that
one is narrow pulses and the other for wider pulses. Simple RC filter
with no R..
regards,
Leroy
129275@s... wrote:
> Hi,
> enough?
> James.
> from the same email address that you subscribed with. Text in the Subject and
* Leroy Hall *
* 317 Cherokee Drive *
* Loveland, Ohio - USA 45140-2404 *
* Phone: (513) 697-7539 *
* Cell : (513) 300-8632 *
* Email: leroy@f... *
* Home page URL: http://home.fuse.net/leroy/ *
* Resume URL: http://home.fuse.net/leroy/resume.htm *
* Leroy Hall *
what type it is. I scope the power supplies of my projects looking
for noise and oscillations. What I have found it that a .1uF under
the power pins of every chip is a good place to start. More
capacitance would most likel;y be required if the regulator is on a
different board, or if the regulator is far away. Also, the DC ground
should be nice and hefty, there should be lots of it. Having seperate
DC and digital grounds is sometimes a good idea.
Regards
Rich
http://geocities.com/rbc1956
--- In basicstamps@y..., 129275@s... wrote:
> Hi,
choose,
to
> enough?
measure
> James.
sure if I try I could find one somewhere and borrow that.
James.
--- In basicstamps@y..., iceninevt@y... wrote:
> I agree that a scope is necessary to see where the noise is, and of
ground
seperate
> Regards
> Rich
> > Hi,
> choose,
(1.0+0.01uF
not
next
> to
close
> > enough?
other
> measure
> > James.
noise by decoupling, filtering and other methods. If it's still an issue
when you read this, let me know, and I'll drag the link out of my Favorites
into here.
Also, If decoupling isn't the issue here, I wouldn't be surprised. Your ADC
may actually be capturing exactly what the sensor is outputting, and it may
be very non-linear (as are many fast sensors - they are actually too fast at
times.)I've found that many types of sensors throw oddball values that we
might consider noise, which in a faster process would be less significant.
If these odd values are being output just as the stamp is reading the input,
it makes the result much worse that reality. You may want to start by
averaging the inputs and setting a range with high and low limits as a
simple filter. There was a nice thread on this list a couple of months ago
that contained some methods, from simple to complex, that really work. I
believe Tracy was the expert in this area.
If the decoupling works, sorry - sometimes I just like to hear myself talk
(or type) and I'll be glad you found a simple solution.
Chris
> From: 129275@s... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=K0hEVYh6-j1E6cNvgQerk28vFgofZAsCMoBzmwl_aJSOfLeJjaH2UGu8juT237iK034bXC0nWR8cuR0MGQ]129275@s...[/url
> Sent: Tuesday, June 26, 2001 9:42 AM
> Subject: [noparse][[/noparse]basicstamps] Re: Decoupling capacitor advice
> Ok, thanks for the ideas. I don't have a scope unfortunately, but I'm
> James.
> ground
> seperate
> > Regards
> > Rich
> > > Hi,
> > choose,
> (1.0+0.01uF
> not
> next
> > to
> close
> > > enough?
> other
> > measure
> > > James.
> in the Subject and Body of the message will be ignored.
wrote:
> There are a couple of super websites full of excellent advice on
managing
issue
Favorites
> into here.
Yes please, if you could let me have those links I'd appreciate it.
Your ADC
and it may
too fast at
that we
significant.
the input,
by
as a
months ago
work. I
myself talk
I won't have a chance to try it until probably the beginning of next
week (kind of busy this week, and the weekend is booked up too). But
yes, a software solution by averaging inputs was something else I was
considering.
Thanks alot, James.
line noise.
I deal with pressure sensors quite often and one thing most people
don't realize is that sound is a pressure wave. I get involved in
fractions of an inch of water full scale (27.72 inches is close to 1
psi)
The noise might be sound. I would agree to check the scope to see
the frequency. Airplanes use a static pitot tube for velocity. In
HVAC, we use ultra low pressure transmitters, and usually integrate
the heck out of them to kill the noise. Don't forget wind noise is a
possibility, as well as vibration of the sensor itself.
With your range in the PSIG, you might not see as large a problem,
but it might be beneficial to test your sensor by playing the stereo,
holding it out the car window at 90 mph, or singing to it.
I don't recommend breaking any laws, so tell your wife you need to go
to Germany and drive the Autobahn : ) and to Japan to sing Karaoke,
and invite the neighbors for a party : )
Dave
> Hi,
choose,
to
> enough?
measure
> James.
http://www.williamson-labs.com/480_byp.htm
http://www.ednmag.com/ednmag/reg/1995/090195/18df5.htm
I noted a later posting about lead length, etc....
I try to stick to a 1mm rule for the + lead to the Vcc pin and I double the
trace width of Vss. Especially with very busy chips, such as a binary
counter, where there are always many gates switching I often find a need to
use some combination of .01, .1, and 1 uF caps, at times, all three.
BTW, how is Swansea this time of year? I'm on an ISO committee that met at
the University there last year in the fall - during your petrol "crisis".
Somehow, the people were all very friendly despite the pressure of the day.
And, how did The Mumbles ever get it's name? Why not Thomasville, or
something?
Chris
> From: 129275@s... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Ckq_iVrhjA2Vs4MByiEWfFcxMO4F5hImFp2ExbkYzzMofol4SmgFaq8CItuJQVHzgDqxhIfkAus3s0WMzR0]129275@s...[/url
> Sent: Tuesday, June 26, 2001 11:43 AM
> --- In basicstamps@y..., "Chris Loiacono (E-mail)" <chris01@t...>
> managing
> issue
> Favorites
> > into here.
wrote:
> Decoupling links, as promised:
Thanks for those, they look quite interesting, though I haven't had
chance to read them properly yet.
met at
petrol "crisis".
the day.
> something?
Swansea is great this time of year. Weather is good, warm (but not
hot), dry, sunny. Unfortunately the rest of the year it can be fairly
crappy (grey, wet, windy). Great place to be at University though,
what with the beach right there, and the Gower peninsula a few miles
away. And I've no idea how The Mumbles got its name.
James.
