common neutral AC power
Hi dave,
Let me know if I correct your schematic correctly.
--- AD VCC
AD input
R-1 D-1 R-2 P-1
Signal ---/\/\---->|----/\/\----[noparse][[/noparse]pot]
AD gnd
= cap
signal gnd
to common neutral (one wire of AC power)
Your signal is referenced to common neutral?
AD gnd and signal gnd are floating (i.e 2 separate power supplies)?
How did you connect the multimeters and which gave stable reading on what
range (V= or V~)?
Greetings peter
--- AD VCC
AD input
R-1 D-1 R-2 P-1
AD gnd
= cap
signal gnd
range (V= or V~)?
Greetings peter
you are correct in your schemaitc but you did not show that all
grounds are tied together.
I am attempting to use the 24 VAC through a rectifier and 7812 to get
12 VDC for alarms
One multi meter was autorange and that never settled. the other was
set on 10VDC and was very stable.
Dave
--- In basicstamps@y..., "Peter Verkaik" <peterverkaik@b...> wrote:
> Hi dave,
> --- AD VCC
AD input
> R-1 D-1 R-2 P-1
> Signal ---/\/\---->|----/\/\----[noparse][[/noparse]pot]---|-- AD gnd
> = cap |
> signal gnd
on what
> range (V= or V~)?
> Greetings peter
chances are the meter is picking up noise.
> 12 VDC for alarms
