Getting data into Excel
Hi folks,
I am working on a system that takes real time data from a stamp and then
interfaces to a standard x86 box via the serial port. I want to get the
information into MS Excel spreadsheet. I'm pretty good at writing macros in
Excel and I have VisualBasic5 Pro. The question is: what is the most
reasonable way to get small amounts of data from a VB5 program into Excel
automatically.
The ways I am looking at are:
1. Use the clipboard
2. code a VB5 dll and use a call from Excel (not sure about this, never done
it).
3. Use OLE/activex and getobject (again, not sure about this, never done it).
Ideas would be much appreciated.
Scott.
automatically.
it).
Scott.
save the file as a ".csv" (comma separated values) file. eg. "myfile.csv".
The .csv extension automatically gives the file an excell icon.
Try this, in notepad exactly as follows...then save it as "sample.csv"
Then from 'Documents' menu, double click it to open the file in excell..
Regards, Chris
Heading,22/06/2000
Col 1,Col2,Col3,Col4
3,5,15,6789
3.76,22389,67
Sent: Saturday, June 23, 2001 9:41 AM
Subject: [noparse][[/noparse]basicstamps] Getting data into Excel
> Hi folks,
in
> automatically.
done
> it).
it).
> Thanks,
> Scott.
> from the same email address that you subscribed with. Text in the Subject
Thanks for the idea, but the data has to be transfered to Excel in real time
and without user intervention. Excel has a looped macro that formats and
displays the information (also in real time).
Scott
> Simply....
> Regards, Chris
How about _appending_ the data it to an existing text file.
Excel would be pre-linked to that text file via ODBC. You
would need a macro in excel that ran on a timer interval to
regularly refresh the query...Bet a paycheck that will work...
Ken Ambrose
with enough thrust, pigs fly just fine.
---- On Fri, 22 Jun 2001, scottsmith13@a...
(scottsmith13@a...) wrote:
> Hi Chris,
Excel in real
> time
formats and
> Regards,
> Scott
> > Simply....
eg.
> "myfile.csv".
icon.
> "sample.csv"
file in
> excell..
> > Regards, Chris
in the
recently did a program that processes raw data files and beautifies them
in Excel, all from the VB executable. You could modify this technique to
give the desired effect. I can send you my source if you'd like, and a
sample data file.
Stew Benedict
The power in technology lies in getting it to
work the way you do, we can help.
Stew Benedict *** AYS Enterprises *** stewb@c...
http://www.crosswinds.net/~stewb ICQ: 18063833
http://www.aysenterprises.com Phone/Fax: 216-228-3983
On Fri, 22 Jun 2001, Ken Ambrose wrote:
> Hi,
> Ken Ambrose
> > Hi Chris,
> Excel in real
> > time
> formats and
> > Regards,
> > Scott
> > > Simply....
> eg.
> > "myfile.csv".
> icon.
> > "sample.csv"
> file in
> > excell..
> > > Regards, Chris
> in the
> from the same email address that you subscribed with. Text in the Subject and
> it).
If you want to add and alter the data in real time, your best bet
would be #3. If I remember correctly, you should be able to do
anything with OLE that you would normally do via the user interface.
For example, you could have your VB app open Excel, get a saved
spreadsheet, set the values of specific cells, and close it again.
Here's an example from Microsoft:
http://support.microsoft.com/support/kb/articles/Q112/4/17.ASP
SD
| Steve DeGroof (http://degroof.home.mindspring.com/) |
Sent: Saturday, June 23, 2001 11:22 AM
Subject: Re: [noparse][[/noparse]basicstamps] Getting data into Excel
> Hi Chris,
time
> Regards,
> Scott
> > Simply....
"myfile.csv".
excell..
> > Regards, Chris
