Cables?
Does anyone make small cables with .1" non-polarized connectors to fit
standard .025" square posts? For example, a 12" two conductor cable with
Jameco # 100811 connectors to fit standard male headers.
I shake too much to make these up myself. I burn everything. Or is there
some fancy tool that I don't know about?
Jay
Jay
the connector sockets to the wires, but you aren't soldering around the
plastic. These are the connectors similar to what they use on CD-ROM audio
cables.
Jay,
I like Panduit's insulation-displacement MAS-CON .100" series, because
they're quick to install (no wire stripping required) and the punch-down
tool is relatively cheap (compared to Amp). The main disadvantage is that
you have to stick to a single wire size per connector. Newark is one source...
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
listed at $9.95 in their latest catalog.
Bob Baxter
>Jay
>from the same email address that you subscribed with. Text in the Subject
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
