i button lock
Walt-
Here's a starting place showing some working code:
http://groups.yahoo.com/group/basicstamps/message/9435
FWIW, you could do all your 1-wire stuff using just one Stamp I/O pin
(your 1-wire network might even like it better). By the time you
get through hanging LCDs, keypads, toasters etc. off your Stamp, you
may wish you had minimized your 1-wire I/O pin requirements.
Steve
On 20 Jun 01 at 4:39, walt wrote:
> can someone help with a project using a bs2p to read ds1990a serial
> number using a ds9092l...
Steve
number using a ds9092l for contact point.i would like to have 4 doors
each using it's own pin for one wire and another for door lock at
some point i would like to use a serial lcd and a 12 key keypad for
status and programing changes(to register new keys and witch doors it
can open.i am new to bs2 and 1 wire so ex.would be nice.
walt@f...
for 15 sec. the unit would have 8 to 10 keys that could be used 1
would be a master used to program keys and also open all doors others
would open only 1 or 2 doors.
the hardware
6 ds9092l ibutton probe with led (1 per.door)
6 relays (1 per. door strike)
6 door switches (1 per.door(door open?))
bs2p40
12 key keypad with 8 connections (i don't know how to use this?)
1 4*20 ser.lcd (would like to use for programing and stats)
i nead as much help as poss. walt
walt@f...
