Help with using BASIC stamp with Visual Basic
Archiver
One possibility:
http://home.earthlink.net/~parkiss/capture/CAPTURE.ZIP
A means to program a Stamp via a DOS program without the Parallax
editor/loader.
Steve
On 19 Jun 01 at 23:57, JoeBruscella@c... wrote:
> ...Is there any way using VB or with the stamp2.exe so that it will
> automatically execute the program without having to manually type
> ALT+R? In essence, having the program "hit" ALT+R for you.
editor/loader.
Steve
A friend and I are using the BASIC 2 stamp from Parallax along
with the stamp2.exe compiler (the DOS command line version) from
Parallax. We are making a program with Visual Basic that will, using
the "Shell" command, execute the stamp2.exe program and then run a
saved program that we made. The problem we are having is that there
is no way to have stamp2.exe execute the program automatically, you
must manually hit ALT+R.
Thanks in advance.
Private Sub Form_Load()
'SendKeys Statement Example
'This example uses the Shell function to run the
'Calculator application included with Microsoft Windows.
'It uses the SendKeys statement to send keystrokes to
'add some numbers, and then quit the Calculator.
'(To see the example, paste it into a procedure, then run
'the procedure. Because AppActivate changes the focus to
'the Calculator application, you can't single step through the code.).
Dim ReturnValue, I
ReturnValue = Shell("CALC.EXE", 1) ' Run Calculator.
AppActivate ReturnValue ' Activate the Calculator.
For I = 1 To 100 ' Set up counting loop.
SendKeys I & "{+}", True ' Send keystrokes to Calculator
Next I ' to add each value of I.
SendKeys "=", True ' Get grand total.
SendKeys "%{F4}", True ' Send ALT+F4 to close Calculator.
End Sub
Mike Witherspoon
[noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9Ed8DDD8VVkXmWZ-_vHPFUrkDtaFyTYV45cJZ9muzrrhwevGZQinmHBOo9nkzMUmuSIVC82619SiwFtdJz-7FNgZDosHZlIP]JoeBruscella@c...[/url
Sent: Tuesday, June 19, 2001 5:04 PM
Subject: [noparse][[/noparse]basicstamps] Help with using BASIC stamp with Visual Basic
Sorry about the re-post...I forgot to add a subject line...
Thanks in advance.
from the same email address that you subscribed with. Text in the Subject
>Hi,
>Thanks in advance.
There is a program that I have used in the past called "PB" <-not sure
exactly why that name was chosen, but it allows you to "STUFF" the
keyboard with a pre-recorded character sequence. The only thing you
might need to do different is to run a *.BAT file from the Visual
Basic "Shell" instead. The BAT file would then invoke PB.EXE and the
stamp2.exe program. I don't have it here at work since we mostly use
UNIX based machines, but I'll see if I can dig it up at the house
tonight and have it for tomorrow.
Beau Schwabe IC Mask Designer
National Semiconductor Wired Communications Division
500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
--- Beau Schwabe <bschwabe@a...> wrote:
> line...
> >Hi,
> Parallax along
> version) from
> that will, using
> and then run a
> automatically, you
> that it will
> manually type
> for you.
> >Thanks in advance.
> to "STUFF" the
> The only thing you
> from the Visual
> since we mostly use
> at the house
> Division
> Norcross, GA 30071
> with. Text in the Subject and Body of the message
> will be ignored.
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail
http://personal.mail.yahoo.com/
