BasicStamp2 and 4528 One Shot — Parallax Forums
edited 2001-06-18 18:26 in General Discussion
I've tried hooking up a 4528 one shot just like the "Positive One-
Shot" on page 27 of Forrest Mims' "Engineer's Notebook".
I want to trigger on a brief pulse so that my stamp can catch
the wider one-shot pulse in a loop.
I've got a 100uF electrolytic cap and a 10K resistor to set the pulse
width, which works out to .5RC so says Forest which figures out to
about a half a second.
No matter what I apply to pin 4 on the 4528 I can only get the one-
shot to send out the pulse when I first apply power to it
Anyone got any tips on one-shots?
Mark
    edited 2001-06-17 18:29
    Hi Mark, What are you doing with the unused pins? Burt Schultz
    Mark,
    You will have much better luck with a larger R and smaller C. The original
    RCA data sheets for the 4528 (and it's little brother the 4538) warn
    against large value electrolytic caps (100µF would qualify, here). I don't
    see it in the current data sheets from Motorola or National. They do,
    however, point out the other problem with large caps; the need to add a
    series reverse biased diode to Vdd to protect against power surges on power
    down.
    In non-retriggerable monostable mode with a rising edge trigger, connect
    pin 5 to 7, connect input to pin 4, connect pin 3 to Vdd, connect pin 1 to
    Vss (gnd), connect your cap between pin 1 and 2, connect your resistor
    between pin 16 (Vdd) and pin 2.
    Make sure that you tie unused inputs to ground on the unused section.
    Try a 1M resistor and a 1µF. You'll find it works just as well!
    >Mark
    >from the same email address that you subscribed with. Text in the Subject
    >and Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    _________________________________
    Mike Walsh
    walsh@i...
