hysteresis
Hi Patmat,
Instead of a single point you could use a window
For example
If newvalue > oldvalue + 3 then speedup
If newvalue < oldvalue - 3 then speeddown
This implicates that if newvalue is within +/- 3 from oldvalue, speed is
maintained
Hope this helps
Greetings peter
- original message -
Hysteresis can be our friend, at least in certain control situations.
For example, I may have an adjustment knob (a pot) right on a spot
that causes a system to oscillate between two states (a step
function).
Question: How can you build hysteresis into a stamp program? I'm
reading a pulse width; once the pulse gets wider than X, I go from
one operating speed to another. I want to avoid juddering between the
two states.
patmat
from the same email address that you subscribed with. Text in the Subject
For example
maintained
Hope this helps
Greetings peter
function).
two states.
patmat
