atomic time with BS2
Hi Jeff,
Something like that is already there as I found the following message:
(electronic world)
EW403.3 Atomic clock interface ..... Ed Buckley
September 1997, p748
"Changing times". Atomic clock interface which takes the rather unfriendly
serial data from an MSF receiver module and turns it into an RS232 time and
data stream using a Basic Stamp. Output is a bcd data stream containing
year, month, date, day, hour and minutes.
Hope this helps.
Greetings peter.
(electronic world)
Hope this helps.
Greetings peter.
Check out: http://www.ulio.com/timepr.html
Model 325 is a receiver with rs232 output
Datasheet: ftp://ftp.ulio.com/m325ds.pdf
Gives detail info on string output that
Can be used by a stamp.
Success.
Greetings peter
