serial ports
[font=arial,helvetica] Hello everyone!
I am looking for binouts of PC ·(DB-9) an Mac ( mini DIN8M) serial ports. I
need ·one of these adapter cables and I could never find one. I figured out
that instead of using a whole bunch of adapters I could make one on my own.
Can somebody please help me?[/font]
different standards (RS-232 and RS-422).
Greg
--- In basicstamps@y..., parkan197@a... wrote:
> Hello everyone!
> I am looking for binouts of PC (DB-9) an Mac ( mini DIN8M) serial
ports. I
> need one of these adapter cables and I could never find one. I
figured out
my own.
Dennis
From: parkan197@aol.com [noparse][[/noparse]mailto[noparse]:p[/noparse]arkan197@aol.com]
Sent: Tuesday, June 12, 2001 2:26 PM
Subject: [noparse][[/noparse]basicstamps] serial ports
[font=arial,helvetica]Hello everyone!
· basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed with.· Text in the Subject and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
[/font]
has an adapter they call "Printer cable", page 180
latest online catalog part #181382 $3.95, it has 8-pin
mini DIN male to DE9 female. They might be a good
source for parts if the pin outs are not correct.
--- gregory-wagner@u... wrote:
> See URL <http://ftp.sunet.se/hwb/> but be aware
> these are two
> Greg
> > Hello everyone!
> mini DIN8M) serial
> ports. I
> never find one. I
> figured out
> could make one on
> my own.
> with. Text in the Subject and Body of the message
> will be ignored.
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
a year! http://personal.mail.yahoo.com/
their catalog.
> I don't know about the pin outs but Jameco(jameco.com)
only data transfer protocol?
--- In basicstamps@y..., gregory-wagner@u... wrote:
> See URL <http://ftp.sunet.se/hwb/> but be aware these are two
> Greg
> > Hello everyone!
serial
> ports. I
> figured out
on
> my own.
push-pull from 0 to 5V. They only specify the electrical operation. Data
protocol can be what ever you want though usually 7 or 8 bit ASCII with a
Start bit and Stop pause.
> What is the difference between RS-232 and RS-422? Is it voltage or
although if I recall correctly, you are off with
voltages. I recommend B&B Electronics RS-422/485
Application Note at
http://www.bb-elec.com/tech_articles/rs422_485_app_note/table_of_contents.asp.
RS-422 is differential - instead of one each RXD and
TXD referenced to GND, 422 uses a positive and
negative of each transmit and receive (+7 VDC and -7
VDC, I think), so to convert to EIA/TIA-232c you must
combine the transmit signals together and the receive
signals together, and adjust the voltage; also,
possibly, handle handshaking, though not in the
Stamp's context.
B&B has some converters, I think some under $30, some
between $50 and $120. Black Box also has some, in a
slightly wider price range.
Bob Pence
--- Mike DeMetz <miked@t...> wrote:
> RS-232 is single ended, with a plus and minus
> voltage swing. RS-422 is
> Is it voltage or
> will be ignored.
Do You Yahoo!?
Spot the hottest trends in music, movies, and more.
http://buzz.yahoo.com/
