Menu''s messing up using procomm
You may need to send a line feed as well as the carraige return. Give
it a go and see what happens.
James
--- In basicstamps@y..., Eric Haskins <wirelesstech71@y...> wrote:
> I have a controller board I built using a BS2. This is
> used to control a Vibco SCR controlled vibrator. We
> will be interfacing (sending scripts to control speed
> of motor ) via a cisco terminal server (network to
> serial) The menu's I wrote display fine in the debug
> window but in procomm and hyperterm they don't produce
> a carriage return hence the menu's overwrite. This is
> a cosmetic fix I know but I would like to know if
> anyone has seen or done this
> Thanks,
> Eric
James
> Thanks,
> Eric
