PC to stamp2 communication.
I'm pretty new to this group and stamps. I have a stamp2 and was
wanting to use it as a interface to my pc. Meaning, I want to create
mini pc controlled robot arm. I am a pretty good C++ and VB
programmer. So last night I wrote a quick program to open an serial
port and send a character to the stamp. When the stamp receives the
character it was to make a sound. Pretty simple, one would think.
It appears that everytime I open the port for communication the stamp
resents. The manual said something like a modification would need to
be made to allow the pc 2 stamp communication to occur, but I didn't
quite understand what change was required. Can someone in the group
HELP????
HELP????
http://www.al-williams.com/wd5gnr/stampfaq.htm
Here's the short answer.
If you use port 16 (the programming port), the Stamp "steals" -12V from the
serial receiver. This has a few byproducts:
1) You can only do half duplex communications
2) Everything the other computer sends appears to be echoed back -- even if
the Stamp is "dead" or not listening
If you don't use port 16 (you can use any pin you like) you have a problem.
The RS232 standard typically uses +/- 12V (some +/-5V) to represent 1 and 0.
The Stamp uses 0 and 5V -- not a good match. There are two answers:
1) Use a converter like a MAX232/MAX232A/MAX233 etc. Or, if you have +/- 12V
you could use a 1488/1489 combo but for most people the MAX chips are a
better fit.
2) Invert the serial output and try to drive the receiver with 0 and 5V. So
instead of using 84 in the baudmode, you'd add (I think) $4000 to it (check
the manual). The problem is, not all devices will appreciate this. Also, if
you want to drive the Stamp from a +/-12V RS232 input, you need a limiting
resistor (22K) to keep from blowing the Stamp up.
While this method is not very reliable, I've used it many times and it works
in nearly all cases.
Al Williams
AWC
* Floating Point A/D:
http://www.al-williams.com/awce/pak9.htm
> From: Tim Carroll [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tpEYg0MlHBQbDpackuVACnWq3Y2ML1n-gOeqkyZdlRwaWiHbR_cofyZmaAbnssA_ydoj3JCsUoQ]ztc0327@y...[/url
> Sent: Tuesday, June 12, 2001 9:26 AM
> Subject: [noparse][[/noparse]basicstamps] PC to stamp2 communication.
> HELP????
> from the same email address that you subscribed with. Text in
> the Subject and Body of the message will be ignored.
problem.
Isn't there something about disconnecting the ATN pin on the Stamp either
via a switch, or with a decoupling cap he should consider, too? Possibly
even a software change on the PC to not assert DSR (?) ?? I don't have
may manuals handy so I can't look this up.
On Tue, 12 Jun 2001 09:51:33 -0500 "Al Williams" <alw@a...>
writes:
> This is answered in the Stamp FAQ at
> from the
> even if
> problem.
> 1 and 0.
> +/- 12V
> are a
> better fit.
> 5V. So
> (check
> Also, if
> limiting
> it works
> Regards,
> Al Williams
> AWC
> > From: Tim Carroll [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5WGtkkRQH2sr_U-fppC9ygTGxPXdTSI9L15WHyqwsZSO9tzDJmnGCSdoM3N6WdKn2lkprbTPiKUm2vN6]ztc0327@y...[/url
> create
> serial
> the
> stamp
> to
> didn't
> group
> > HELP????
> from the same email address that you subscribed with. Text in the
