bitwise vice versa?
I have a BS2, and am wondering how you do this:
lets say we have a number %10101010 (170)
what piece of code will make it equal %01010101 (85)
at the moment I simply subtract the number from 255 (255 - 170 = 85),
does the BS2 have a built in function for doing this?
The REV function will provide the same result. Check the Stamp Manual for
details.
REV %10101010 8
Hope that helps
Bruce Bates
noticed your examples are reverses of each other and his answer, of course,
is correct for that situation.
Not having had enough caffeine yet, I noticed first that the example is
right shifted so :
x=%10101010
x=x>>1
Would do that.
But on reflection, I noticed that the result is also inverted:
x=x^$FF ' if I recall correctly
Does any of that help?
Al Williams
AWC
* Control 8 servos at once: http://www.al-williams.com/awce/pak8.htm
> From: mbarron.geo@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WU7K9mPkZWoJF2nB21uG2Et2qWcwbAHXfEOmyg9l8Fo2qaFxiAwMdi4yeaCCzUnRoEWhiH7GCZbDTvSoiVkW]mbarron.geo@y...[/url
> Sent: Monday, June 11, 2001 5:11 AM
> Subject: [noparse][[/noparse]basicstamps] bitwise vice versa?
> from the same email address that you subscribed with. Text in
> the Subject and Body of the message will be ignored.
or y = ~x
inverts the state of each bit. But like Al says, the problem is
ambiguous. We need more examples of what you want to do. For
example, if your input is,
x=%00110110 (54)
what do you want to happen with that?
y=~x ' gives %11001001
y=x ^ $ff ' also gives %11001001
y= x rev 8 ' gives %01101100
y= x >>1 ' gives %00011011
y = 255 -x ' gives %11001001 (201)
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
mbarron.geo@yahoo.com writes:
lets say we have a number ············%10101010 (170)
No.
[/font]
mostly at the bit level, I am using either
x = ~y ' or
x = 1 - y ' for byte would be x = 255 - y
Does anyone have a sense which of the three methods -
subtractive, inverse, and xor - taxes the processor
least? How about token storage? Is inverse (~)
preferable for readability and consistency? Obviously
this isn't important on a small scale, but I am nearly
filling two program slots and want to maintain the
current structure. This requires a lot of math-based
decisions because of the limitations of PBASIC's IF...
THEN.
My favorite line takes a 12-bit pressure transducer
reading stored in a word, accounts for zero, and
lights an LED if either one valve is on and the
pressure has reached the low target, or the other
valvs is on and the pressure has reached the high
target (only one valve is ever on at a time):
AD = AD + 1 ' in case of zero reading, no div by 0
OUT14 = (OUT12 * (p_low + 1) / AD) + (OUT13 * AD /
(p_high + 1))
' given: OUT12 + OUT13 <= 1
Bob Pence
> (170)
> (85)
> (255 - 170 = 85),
> this?
> or y = ~x
> the problem is
> to do. For
> x=%00110110 (54)
> -- regards,
> Tracy Allen
> mailto:tracy@e...
> with. Text in the Subject and Body of the message
> will be ignored.
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
a year! http://personal.mail.yahoo.com/
Nice pressure xducer formula!
The method using ~ will always be the fastest and require the least
memory. We can always test out the alternatives by looking at the
memory map (CTRL-M). Brian Forbe's book has lots of info on the
length of code for different operations. Since the number of bits
that the interpreter has to read will almost always dominate the
speed equation, fewer tokens almost always works out to faster speed.
-- best regards
Tracy Allen
mailto:tracy@e...
>I have a number of places in my current project where,
>x = ~y ' or
>THEN.
>(p_high + 1))
>Bob Pence
>> (170)
>> (85)
>> (255 - 170 = 85),
>> this?
>> or y = ~x
>> the problem is
>> to do. For
>> x=%00110110 (54)
>> -- regards,
>> Tracy Allen
>> mailto:tracy@e...
