mcp3204 code
help, help.
ive spent hours trying to make this work, no luck.
ive used the stamp code for the ltc1298 a 2 d converter, i just modified it
for the demands of the mcp3204.
all i can ever get is all zeroes.
ill attach the code as a file at the end.
any help is greatly appreciated.
normdoty@h...
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com
normdoty@h...
Try putting 12 instead of 16 in the shiftin command
Best regards,
Kalun mailto:klnlau@v...
Sunday, June 10, 2001, 7:29:27 AM, you wrote:
nd> help, help.
nd> ive spent hours trying to make this work, no luck.
nd> ive used the stamp code for the ltc1298 a 2 d converter, i just modified it
nd> for the demands of the mcp3204.
nd> all i can ever get is all zeroes.
nd> ill attach the code as a file at the end.
nd> any help is greatly appreciated.
nd> normdoty@h...
1 to run the conversion, and 1 which clocks out an unknown bit, ive tried
all combinations from 12 to 27, it will clock out the data backwards after
its forwards reading if you keep sending clock pulses, and after that if
clocks are still supplied its supposed to clock out zeroes indefinately.
any other ideas would be appreciated.
norm
>From: Kalun Lau <klnlau@t...>
>Reply-To: basicstamps@yahoogroups.com
>To: norman doty <basicstamps@yahoogroups.com>
>Subject: Re: [noparse][[/noparse]basicstamps] mcp3204 code
>Date: Sun, 10 Jun 2001 08:37:08 -0500
>Hello norman,
>Best regards,
>nd> help, help.
>modified it
>nd> normdoty@h...
>from the same email address that you subscribed with. Text in the Subject
>and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
sure what the difference is
The Shiftin / Shiftout routines work extremely well with several ADC/s that
we use in production. I've pasted a snipet of code we use in one of our
instruments which contains an LTC1298. This code has also been reliably
tested with the newer Microchip MCP3202. The averaging gives us somewhat
better than the 12 bits these A/D's are rated at.
For x = 0 to 4
AdConfig=AdConfig|%1011 ' set all bits xcept
OddSign
CS = 0 ' Low CS-enable ad
shiftout data_io,clk,0,[noparse][[/noparse]AdConfig\4] ' send config bits
shiftin data_io,clk,2,[noparse][[/noparse]Analog\12] ' get result data bits
CS = 1 ' High CS-disable
Temperature=Temperature+Analog ' Sum A/D bits
Next
Temperature=(Temperature */ 125 + 1)/2 ' A/D reference voltage to
'5.000VDC; average of 5 counts
norman doty wrote:
> the mcp3204 docs says you need 3 extra clock cycles, 1 to latch the data in
> norm
> >Hello norman,
> >Best regards,
> >nd> help, help.
> >modified it
> >nd> normdoty@h...
> from the same email address that you subscribed with. Text in the Subject and
sclock - pulled up to 5vdc using a 47k resistor and connected to stamp
cs = pulled up to 5vdc using a 47k resistor and connected to stamp
norman doty wrote:
> help, help.
> normdoty@h...
> mcp3204.bs2 Type: Plain Text (text/plain)
> Encoding: 8bit
a lot) but it didnt help, i replaced the chip with a 3202 and made the code
changes for it and now it works.
dont know if i had a nad 3204 or bad pins on the stamp2
normdoty@h...
>From: "L .Gaminde" <lgaminde@t...>
>Date: Sun, 10 Jun 2001 08:16:23 -0700
>Here is one other little tidbit
>norman doty wrote:
> > help, help.
>it
> > normdoty@h...
>Subject and Body of the message will be ignored.
> > Encoding: 8bit
dont know if the 3204 was bad or bad pins on the stamp2
thanks
normdoty@h...
>Date: Sun, 10 Jun 2001 08:05:04 -0700
>don't know if this will help I think I have one more this is a 3202 not
> For x = 0 to 4
>OddSign
> Next
>to
>in
>tried
>after
> > norm
> > >Hello norman,
> > >Best regards,
> > >nd> help, help.
> > >modified it
> > >nd> normdoty@h...
>Subject
