ScrewedUp
Just started, Connected P0 to the +5V·rail when trying to setup an LCD display. Have I fried the BST2 or the LCD. Any commets welcome, be nice I am not·well diversed in electronics. Just having fun by purchasing·a StampWorks kit from Parallax and made it to Experiment #11: A basic LCD Demonstratiion. Quote unQuote after loading the code nothing visualy hapened and then I realized (after checking), I had connected the LCD·"E" pin at the junction of·a 4.7K resitor·ground wire to the +5V rail. The schematics:
P4 --- D4
P5 --- D5
P6 --- D6
P7 --- D7
P0 --- * --- E
······· 4.7K
···· Ground (ScrewUp connected to +5V)
P3 --- RS
· ·· ·---· R/W
Ground
I do not· know the consequenences of connecting the ground to a vlotage in this case and need to now if I have damaged the PS2 or the LCD. Any help would be greatful.
P4 --- D4
P5 --- D5
P6 --- D6
P7 --- D7
P0 --- * --- E
······· 4.7K
P3 --- RS
· ·· ·---· R/W
Ground
be nice I am not well diversed in electronics. Just having fun by
purchasing a StampWorks kit from Parallax and made it to Experiment
connected the LCD "E" pin at the junction of a 4.7K resitor ground
The schematics:
P4 --- D4
P5 --- D5
P6 --- D6
P7 --- D7
P0 --- * --- E
4.7K
P3 --- RS
--- R/W
Ground
I do not know the consequenences of connecting the ground to a
If I understand correctly you tied the Stamp's P0 directly to +5V
while it is used to control the E input of the LCD.
This may have damaged your P0 output as soon as it was pulled low,
creating a short between +5V and ground.
See if the P0 still switches without the LCD using a simple testprogram.
Greetings peter
I went back to the begining and could still flash an LED using P0, rewired
the LCD and ran the program, still didn't display anything on the LCD. When
all else fails adjust the brightness control, simple problem simple
solution. Thanks for your reply, it redirected me to the beginning and I
realized my mistake.
Sent: Saturday, June 09, 2001 4:16 AM
Subject: [noparse][[/noparse]basicstamps] RE:screwedup
> Hi,
> Greetings peter
> from the same email address that you subscribed with. Text in the Subject
http://www.weethet.nl/english/basicstamp2_lcdcontrol.htm
Hans Luyten
Webmaster http://www.weethet.nl
From: Terry Neider [noparse][[/noparse]mailto:tn9821@hotmail.com]
Sent: zaterdag 9 juni 2001 10:50
Subject: [noparse][[/noparse]basicstamps] ScrewedUp
P4 --- D4
P5 --- D5
P6 --- D6
P7 --- D7
P0 --- * --- E
······· 4.7K
P3 --- RS
· ·· ·---· R/W
Ground
· basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed with.· Text in the Subject and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
