Max186ACPP
MAX186 is 8ch 12 bit serial AD converter that could be easily interfaced
to BS2 (4 pins). There are several resources avaiable about interfacing.
I think it could be find at Parallax listings or tech doc. Remember to
use the recomended filter capacitors as stated in the data sheet.
ACJacques
Tad Heckaman wrote:
> I have two chips that I would like to use, mainly for the experience.
> It is made by maxim and it says on the chips MAX186ACPP 0114. I think
> it is a analog to digital converter, but it could be some thing else.
> What ever it is, is there any way to hook it up a basic stamp 2
> in some useful way? I want to learn how to use analog to digital
> converters to see how I could use it.
> Tad
> from the same email address that you subscribed with. Text in the
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
ACJacques
> Tad
Check out: http://www.high-techgarage.com/tutorial/max187.php
Although it is made for the MAX187 (a single channel "cousin" of the
MAX186) most of the information will apply to the MAX186, i.e. using
shiftin and shifout to interface with a 3-wire device. Conceptually
they are very similar. With the MAX186, however, you have to choose
which channel you want to take data from. You could always request
some samples for the MAX187, use the tutorial, and get that working.
Once you master a 1-channel ADC, you can easily move on to the 8-
channel!
BTW...the ACPP is Maxim's code for a DIP package. The base number
(MAX186) refers to the part.
Good luck with your project!
--Jeff Wallace
*Add a RTC, 256k EEPROM, 8 extra I/O, and an 8-channel ADC to the BS2
http://www.high-techgarage.com/products/supermax.php
> experience. It is made by maxim and it says on the chips MAX186ACPP
> 0114. I think it is a analog to digital converter, but it could be
> some thing else. What ever it is, is there any way to hook it up a
> basic stamp 2 in some useful way? I want to learn how to use analog
> to digital converters to see how I could use it.
> Tad
http://geocities.com/SiliconValley/Orchard/6633/max186.html
ACJacques
Tad Heckaman wrote:
> Thanks, but where are some Parallax listings? (Is this a stupid question?)
> From: AC Jacques [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dpZgQXLxUR51uumOiF6_OUr1PXii1zj43uj2RjHsiiHoGeYFLQTFdpI6ate7beLUgdaw-6QvM6tN1y7ucQNcNqar]acjacques@i...[/url
> Sent: Friday, June 08, 2001 7:02 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Max186ACPP
http://www.gorobotics.net/adcproject.shtml
The reason it is a "free" A/D converter is because Maxim gives out
free samples. Go to their site and request the part(s) you need.
Tad
From: AC Jacques [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iD_HkV8mDfjhSqRWYlfvqX2uxbmJB0sgdFleeSQd85t8GBf6-2-44zwNITEAc8SS--NCWY52v05xILGOf8DCVJsnxUE]acjacques@i...[/url
ACJacques
> Tad
from the same email address that you subscribed with. Text in the Subject
site it was on. It was a electronics web site that somebody had a link to.
Tad
From: bs2web@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3jvPtuVa-vtRk7HBSsjLPZcTjaBaEfVNUdvXrQ5XTHyJFG7HiugQdWibIwwrpdFMftgKULnysASoTA]bs2web@y...[/url
Sent: Friday, June 08, 2001 7:52 PM
Subject: [noparse][[/noparse]basicstamps] Re: Max186ACPP
Check out:
