PIC16F84 to BS2 using SEROUT
I am trying to network a BS2 as a MASTER with PIC 16F84 SLAVES using
SEROUT/SERIN but am having trouble getting the chips to talk to each
other. I can't get the BS2 to receive anything. Any ideas would be
greatly appreciated.
The PIC generates a signal from a conditional event similar to the
code below (using PicBasic and MPLAB)-
loop:
if PIN0 = 1 Send_it 'If P0 is high goto the Send_it loop.
goto loop
Send_it:
SEROUT 2,N2400,("hello") 'Send "hello" 2400,N,8 on P2.
goto loop
The BS2 MASTER code I'm using looks like this-
hello var word
loop:
SERIN 2,16780,[noparse][[/noparse]hello] 'Receive data 2400,N,8 on P2.
debug hello,13
goto loop
loop:
goto loop
Send_it:
goto loop
hello var word
loop:
debug hello,13
goto loop
Are you using PicBasicPro, or BasicMicro, or assembler?
There are several things wrong with the BS2 master program.
Hello is defined as a word variable, but your PIC is sending a
string. The result is displayed as straight code values, not as
decimal number. No handshaking is implemented on the BS2 master side,
to match that on the PIC side. The result will be quite weird, maybe
displaying a couple of random characters now and then.
Try something like this, which receives the data as a 5 byte string
and implements the handshaking...
hello var byte(6) ' array to receive string
hello(5)=0 ' puts a null terminator on the string.
loop:
SERIN 2\1,16780,[noparse][[/noparse]str hello\5] 'Receive 5 bytes 2400,N,8 on P2.
' when serin is ready, P1 goes high
' connect P1 to PIN0 on your PIC
debug str hello,13
goto loop
or something like this, to receive one character at a time...
x var byte
loop:
SERIN 2\1,16780,[noparse][[/noparse]x] 'Receive 1 byte 2400,N,8 on P2.
debug x
goto loop
In this last one, you have to send the CR from the slave.
If you have an oscilloscope or even a voltmeter, that can be a great
help to see if the signals are behaving as you expect. A tutorial on
this can be found at:
http://www.emesystems.com/BS2rs232.htm#SERINflow
-- regards,
Tracy Allen
mailto:tracy@e...
>other. I can't get the BS2 to receive anything. I've read alot of
>your information regarding Stamps on your web site and it seems like
>you have expertise in this area.
>Any ideas would be greatly appreciated.
> Mark Johnson
>loop:
>goto loop
>Send_it:
>goto loop
>hello var word
>loop:
>debug hello,13
>goto loop
