Averaging a Word sized array?
I am using a bs2 to read a sensor that returns a word sized variable. I
would like to store several samples of this variable in an array and then
average the array in order to "clean up" my results. I have read the section
in the stamp manual 1.9 concerning arrays but I am still confused (as
usual).
Does anyone know of a good tutorial that I might find online?
Jeff
usual).
Jeff
samps con 4
total var word
i var nib
reading var word ' from your subroutine
total=0
for i=1 to samps
gosub read_value ' your routine sets reading
total=total+reading
next i
total=total/samps
' total now has average reading
Al Williams
AWC
* Help beta test new electronics classifieds FREE
http://www.al-williams.com/classad
> From: Jeff & Julia [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=sjzL2FBTC3C4BqaPa8kpbIvrL9AMNXBLIH9mAwgm-AagGBXFtrO8bk0HvkroEF5Js2MooD0IkqBytiXX]EL-JEFE@P...[/url
> Sent: Monday, June 04, 2001 10:34 AM
> To: Basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Averaging a Word sized array?
> the section
> usual).
> Thanks,
> Jeff
> from the same email address that you subscribed with. Text in
> the Subject and Body of the message will be ignored.
>usual).
>Thanks,
>Jeff
Hi Jeff,
No array is needed to compute a simple average. Make an accumulator
to store up the sum of all the readings as they come in, and a
variable to count the number of samples. At the end, divide the
accumulator by the number of samples. (caveat: the accumulation has
to stay less than 65536, else you have to plan for double precision
accumulation.)
If you do want to use an array, it would go something like the following:
myArray var word(5) ' 5 samples
result var word ' readings
i var nib
for i=0 to 4
gosub getData ' not shown
myArray(i)=result
next
' have 5 readings in array
' now find average
result=0
for i=0 to 4
result = result + myArray(i)
next
result = result/5 ' average
debug ? result
end
There is a bit of a tutorial on data filters on my web page at this URL:
http://www.emesystems.com/BS2math5.htm
-- regards,
Tracy Allen
mailto:tracy@e...
Just add the results together as they come in and divide the sum by the
number of samples -- no array needed.
section
> usual).
Why does the stamp limit me to 15 samples for averaging in this situation?
My peak reading is 1810 but when I try to average more than 15 samples the
debug window goes blank. Just curious.
Jeff
Sent: Monday, June 04, 2001 10:01 PM
Subject: Re: [noparse][[/noparse]basicstamps] Averaging a Word sized array?
> Why?
I
then
> section
> > usual).
> from the same email address that you subscribed with. Text in the Subject
