J is for JAVA
Hello group!
It seems that JAVA is popping up quite often in this group (namely,
with the J-Stamp and TINI devices). It seems now would be a good time
to learn it (it should leave enough time before the J-Stamp is
released...).
For years I've been intimidated by JAVA (and C for that matter)
because of its "crypticness". My brother (a EE/CS major) claims that
JAVA is quite easy to learn. However, he got the brains (I got the
looks), and I'm not sure I believe that statement 100%. Is JAVA
relatively easy to pick up? Specifically, what books or learning
aides could be recommended? Will Parallax come up with some JAVA
tutorials for their Stampinclass program?
Any direction or information would be greatly appreciated!
--Jeff Wallace
http://www.high-techgarage.com/
released...).
--Jeff Wallace
tough) , if you have some background in object oriented programming
(C++,smalltalk, etc.). Otherwise, it can be a substantial paradigm-shift.
On Sun, 3 Jun 2001 bs2web@y... wrote:
> Hello group!
> released...).
> --Jeff Wallace
> from the same email address that you subscribed with. Text in the Subject and
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
> Java is an easy language to learn (the language, not the API, which
> can be tough) , if you have some background in object oriented
> programming (C++,smalltalk, etc.). Otherwise, it can be a
are just a handful of statements (if, switch, for, etc.). The complexity is
in the library.
Sun is offering a free set of CDs (4 CDs I think) with Java and 6 online
books, and more at
http://developer.java.sun.com/developer/surveys/restricted/java_jumpstart.ht
ml
This is the "Java JumpStart" CD set.
You have to sign up for developer connection, but that's free. It looks like
a great deal for free.
Al Williams
AWC
* Floating point math for any microcontroller:
http://www.al-williams.com/awce/pak1.htm
> From: bs2web@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vk1fCDUM64EqRaOc6zb63D4vlQorSVEOYiNnVQ8i6sDML6XEATZsoemDADtCR0-ZfLUx7w66eg]bs2web@y...[/url
> Sent: Monday, June 04, 2001 10:12 PM
> Subject: [noparse][[/noparse]basicstamps] Re: J is for JAVA
> What is the API and why is it so difficult to learn?
> the Subject and Body of the message will be ignored.
have to implement many of the API's, so the learning curve goes down
dramatically.
On Tue, 5 Jun 2001, Al Williams wrote:
> The API are the "libraries" that do all the real work. C is similar. There
> in the library.
> books, and more at
> ml
> Regards,
> Al Williams
> AWC
> > From: bs2web@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZRpbaFml1xwWg2ACEPXnKdyBVOSNebsqQRXltrLGpu5s3RbCGCUApWIlOyrRuKL2-NguDnUBkQ]bs2web@y...[/url
You can think of a Java system as being divided into three parts. There are
the tools (the java compiler), the virtual machine, and the runtime
environment (which includes the libraries or APIs).
With a java-native chip the only part of the equation that changes is the
virtual machine. The tools and the runtime environment stay the same, so you
still have exactly the same libraries. From the programmer's perspective the
learning curve is the same regardless of how the virtual machine is
implemented. The availability of standard libraries is one of the largest
benefits of Java because using library code allows programmers to get their
work done faster and more reliably (the assumption being that libraries are
well tested since they are used by many people).
Chris.
> From: Sean T. Lamont .lost. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VQ63T_LCWHpDGDsWlAkxx16V89xuVX1J3HTijNJ5qK0tCJ6WcwcXyItHRQWxjsbst4cblLXqvhAVtviR-Q]lamont@a...[/url
> Sent: Wednesday, June 06, 2001 4:32 PM
> Subject: RE: [noparse][[/noparse]basicstamps] Re: J is for JAVA
> In this context, if there is actually a java-native chip,
> it's unlikely to
> dramatically.
> similar. There
> The complexity is
> > in the library.
> and 6 online
> > books, and more at
> a_jumpstart.ht
> > ml
> free. It looks like
> > Regards,
> > Al Williams
> > AWC
> > > From: bs2web@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=urgBEy-F7MMQ52ZHBXA_2YDwndRiDUsQn07FgYgMs0lsXHec4K1boJmJg8cLR1KTccjeI8AY]bs2web@y...[/url
> the API, which
> in the Subject and Body of the message will be ignored.
> (ServNet)
> Tacoma - Bremerton
> - H. Simpson
both impossible and unnecessary to implement the API's on a
microcontroller.
On Thu, 7 Jun 2001, Chris Waters wrote:
> Hi,
> Regards,
> Chris.
> > From: Sean T. Lamont .lost. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xV55TanxUUtd-lp6lJ3sFcrq49tfcy6UMUSOI3dDHSrJxy9tGBO2nwoGcJwuW-vp-mDtP5r3KAMYjv6YcMI]lamont@a...[/url
> > it's unlikely to
> > dramatically.
> > similar. There
> > The complexity is
> > > in the library.
> > and 6 online
> > > books, and more at
> > a_jumpstart.ht
> > > ml
> > free. It looks like
> > > Regards,
> > > Al Williams
> > > AWC
> > > > From: bs2web@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YeZurlGHsJPwrtucqUZo-qTnHvBChYMKKDG7dpk7QH9qgCQUAsV9oeJy4yMwe6taKxK10x-r]bs2web@y...[/url
> > the API, which
> > (ServNet)
> > Tacoma - Bremerton
> > - H. Simpson
its own set of APIs. (Will the J-STAMP have it's own set API and/or
object oriented?) Personally, I find Object Oriented programming with
JAVA to be quite interesting. Many of the I/O functions for TINI
(LCD, I2C and others) are predefined (similar to the LCD and I2C
commands with the BS2P). You simply have to give the method the
correct data and address and away you go.
--Jeff Wallace
--http://www.high-techgarage.com
> I don't know about particular implementations, but I would argue
> that it's both impossible and unnecessary to implement the API's on
> a microcontroller.
