ADXL202eb Revisited
Should the adxl202 be able to measure gravitational tilt in a stationary
application?
I just received my evaluation board and wired it according to the basic
stamp app notes from Analog device, with the exception of using the vdd and
ground pins of the stamp to power the device instead of using a high and low
pin like their notes suggest. I wouldn't think this would make a difference.
The only way I can get any type of reading at all is when I gently tap the
sensor. I would like to use this device as a tilt sensor in a dynamic
leveling device. (controlling hydraulic solenoids through the stamp and some
relays) I have a little confusion about part of the code on the app notes
concerning the line that reads "count 8,1,freq". My x and y axis inputs
are connected to pin 13 and 14 respectively and I suspect that I should be
counting the number of pulses coming from either one of those inputs. The
App notes have the x and y outputs of the 202 connected to pins 5 and 4 on
the stamp. Help! Do I need to change the values of the capacitors?
Thank in Advance,
Jeff
freq var word
t1x var word
t1y var word
t2 var word
input 13
input 14
low 15
count 8,500,freq
t2=25000/(freq/20)
t1_loop:
pulsin 14,1,t1y
t1y=2*t1y
pulsin 13,1,t1x
t1x=2*t1x
pause 100
debug ? t1x, cr,cr
debug ? t1y, cr,cr
goto t1_loop
application?
Thank in Advance,
Jeff
freq var word
t1x var word
t1y var word
t2 var word
input 13
input 14
low 15
count 8,500,freq
t2=25000/(freq/20)
t1_loop:
pulsin 14,1,t1y
t1y=2*t1y
pulsin 13,1,t1x
t1x=2*t1x
pause 100
debug ? t1x, cr,cr
debug ? t1y, cr,cr
goto t1_loop
I forgot to add the r1 resistor to the chip. D'oh
Now the problem is totally erratic numbers. I assume this is just noise.
How should I go about filtering the results from this device?
Any and all advise will be appreciated.
Thanks again.
T1x var byte
T1y var byte
T2 var byte
Xaxis con 3
Yaxis con 2
pulsin Xaxis,1,T1x
pulsin Yaxis,1,T1y
T1x = 8 * T1x / T2
T1y = 8 * T1y / T2
debug dec T1x, tab, dec T1y, cr
This will work as a tilt sensor.
I hope this helps.
- Brice
stationary
> application?
basic
vdd and
high and low
difference.
tap the
dynamic
and some
app notes
inputs
should be
inputs. The
and 4 on
> Thank in Advance,
> Jeff
> freq var word
> t1x var word
> t1y var word
> t2 var word
> input 13
> input 14
> low 15
> count 8,500,freq
> t2%000/(freq/20)
> t1_loop:
> pulsin 14,1,t1y
> t1y=2*t1y
> pulsin 13,1,t1x
> t1x=2*t1x
> pause 100
> debug ? t1x, cr,cr
> debug ? t1y, cr,cr
> goto t1_loop
> from the same email address that you subscribed with. Text in the
Subject and Body of the message will be ignored.
In your example, where does T2 get it's value?
Jeff
Sent: Wednesday, May 30, 2001 12:42 PM
Subject: Re: [noparse][[/noparse]basicstamps] ADXL202eb Revisited
> Try this:
> T1x var byte
> T1y var byte
> T2 var byte
> Xaxis con 3
> Yaxis con 2
> pulsin Xaxis,1,T1x
> pulsin Yaxis,1,T1y
> T1x = 8 * T1x / T2
> T1y = 8 * T1y / T2
> I hope this helps.
> - Brice
> stationary
> > application?
> basic
> vdd and
> high and low
> difference.
> tap the
> dynamic
> and some
> app notes
> inputs
> should be
> inputs. The
> and 4 on
> > Thank in Advance,
> > Jeff
> > freq var word
> > t1x var word
> > t1y var word
> > t2 var word
> > input 13
> > input 14
> > low 15
> > count 8,500,freq
> > t2%000/(freq/20)
> > t1_loop:
> > pulsin 14,1,t1y
> > t1y=2*t1y
> > pulsin 13,1,t1x
> > t1x=2*t1x
> > pause 100
> > debug ? t1x, cr,cr
> > debug ? t1y, cr,cr
> > goto t1_loop
> from the same email address that you subscribed with. Text in the Subject
RF Transmitter and missed that part. Here it is again:
'{$Stamp BS2}
' ADXL202 TEST
T1x var byte
T1y var byte
T2 var byte
Xaxis con 3
Yaxis con 2
Count 3, 250, T2
T2=250/(T2/5)
MAIN:
debug cls
pulsin Xaxis,1,T1x
pulsin Yaxis,1,T1y
T1x = 8 * T1x / T2
T1y = 8 * T1y / T2
pause 100
goto MAIN
Try that. If it doesn't work, I'll rewrite it and TEST it when I get
home from work. Please let me know...
Later,
Brice
> Thanks for the code Brice.
> Jeff
> From: Brice D. Hornback <bdh@c...>
> > Try this:
> > T1x var byte
> > T1y var byte
> > T2 var byte
> > Xaxis con 3
> > Yaxis con 2
> > pulsin Xaxis,1,T1x
> > pulsin Yaxis,1,T1y
> > T1x = 8 * T1x / T2
> > T1y = 8 * T1y / T2
> > I hope this helps.
> > - Brice
> > stationary
> > > application?
the
> > basic
the
> > vdd and
> > high and low
> > difference.
gently
> > tap the
> > dynamic
stamp
> > and some
> > app notes
axis
> > inputs
> > should be
> > inputs. The
5
> > and 4 on
capacitors?
> > > Thank in Advance,
> > > Jeff
> > > freq var word
> > > t1x var word
> > > t1y var word
> > > t2 var word
> > > input 13
> > > input 14
> > > low 15
> > > count 8,500,freq
> > > t2%000/(freq/20)
> > > t1_loop:
> > > pulsin 14,1,t1y
> > > t1y=2*t1y
> > > pulsin 13,1,t1x
> > > t1x=2*t1x
> > > pause 100
> > > debug ? t1x, cr,cr
> > > debug ? t1y, cr,cr
> > > goto t1_loop
the
the Subject
- Brice
Sent: Wednesday, May 30, 2001 1:39 PM
Ooops... sorry... I cut out a bunch of stuff for my LCD display and
'{$Stamp BS2}
' ADXL202 TEST
T1x var byte
T1y var byte
T2 var byte
Xaxis con 3
Yaxis con 2
Count 3, 250, T2
T2=250/(T2/5)
MAIN:
debug cls
pulsin Xaxis,1,T1x
pulsin Yaxis,1,T1y
T1x = 8 * T1x / T2
T1y = 8 * T1y / T2
pause 100
goto MAIN
Later,
Brice
> Jeff
> > Try this:
> > T1x var byte
> > T1y var byte
> > T2 var byte
> > Xaxis con 3
> > Yaxis con 2
> > pulsin Xaxis,1,T1x
> > pulsin Yaxis,1,T1y
> > T1x = 8 * T1x / T2
> > T1y = 8 * T1y / T2
> > I hope this helps.
> > - Brice
> > stationary
> > > application?
the
> > basic
the
> > vdd and
> > high and low
> > difference.
gently
> > tap the
> > dynamic
stamp
> > and some
> > app notes
axis
> > inputs
> > should be
> > inputs. The
5
> > and 4 on
capacitors?
> > > Thank in Advance,
> > > Jeff
> > > freq var word
> > > t1x var word
> > > t1y var word
> > > t2 var word
> > > input 13
> > > input 14
> > > low 15
> > > count 8,500,freq
> > > t2%000/(freq/20)
> > > t1_loop:
> > > pulsin 14,1,t1y
> > > t1y=2*t1y
> > > pulsin 13,1,t1x
> > > t1x=2*t1x
> > > pause 100
> > > debug ? t1x, cr,cr
> > > debug ? t1y, cr,cr
> > > goto t1_loop
the
the Subject
capacitors the readings settled down nicely. As a matter of fact the code
works well enough for my purposes without the T2 section; I was just curious
where you were getting duty cycle info from. Thanks again.
Jeff
Sent: Thursday, May 31, 2001 1:25 AM
> Did that work for you?
> - Brice
> '{$Stamp BS2}
> ' ADXL202 TEST
> T1x var byte
> T1y var byte
> T2 var byte
> Xaxis con 3
> Yaxis con 2
> Count 3, 250, T2
> T2=250/(T2/5)
> MAIN:
> debug cls
> pulsin Xaxis,1,T1x
> pulsin Yaxis,1,T1y
> T1x = 8 * T1x / T2
> T1y = 8 * T1y / T2
> pause 100
> goto MAIN
> Later,
> Brice
> > Jeff
> > > Try this:
> > > T1x var byte
> > > T1y var byte
> > > T2 var byte
> > > Xaxis con 3
> > > Yaxis con 2
> > > pulsin Xaxis,1,T1x
> > > pulsin Yaxis,1,T1y
> > > T1x = 8 * T1x / T2
> > > T1y = 8 * T1y / T2
> > > I hope this helps.
> > > - Brice
> > > stationary
> > > > application?
> the
> > > basic
> the
> > > vdd and
> > > high and low
> > > difference.
> gently
> > > tap the
> > > dynamic
> stamp
> > > and some
> > > app notes
> axis
> > > inputs
> > > should be
> > > inputs. The
> 5
> > > and 4 on
> capacitors?
> > > > Thank in Advance,
> > > > Jeff
> > > > freq var word
> > > > t1x var word
> > > > t1y var word
> > > > t2 var word
> > > > input 13
> > > > input 14
> > > > low 15
> > > > count 8,500,freq
> > > > t2%000/(freq/20)
> > > > t1_loop:
> > > > pulsin 14,1,t1y
> > > > t1y=2*t1y
> > > > pulsin 13,1,t1x
> > > > t1x=2*t1x
> > > > pause 100
> > > > debug ? t1x, cr,cr
> > > > debug ? t1y, cr,cr
> > > > goto t1_loop
> the
> the Subject
