Pressure sensors...
Hello stampers,
Can anybody suggest a low pressure sensor, to be used for measuring the depth of fluid in a tank. Tank size may be from 2 Metres (6 Feet) to approx 12 Metres (36 Feet) ?.
It is for use with diesel fuel so it needs to be fairly good quality.
Chris
Chris
One possibility is to measure hydrostatic pressure by means of an air-filled tube open at the bottom with a pressure gauge on top.· The gauge does not then have to be special in any way because it comes in contact only with air.· It could be differential, comparing atmosphere + diesel fluid to atmosphere.
Another way could use an acoustic or microwave distance gauge looking down at the surface of the liquid.· This works well with water, no idea about diesel oil.
Hope this is of some help,
Dov
Sent: Wednesday, May 30, 2001 9:31 AM
Subject: [noparse][[/noparse]basicstamps] Pressure sensors...
Hello stampers,
Chris
· basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed with.· Text in the Subject and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
solid-state differential pressure elements would work. Not sure who the
manufacturer is or where to get one -- we used them at work and I "saved"
one or two, but they have no markings. I saw some at Tanners Electronics and
they were made by Motorola. Of course, you can always use the fill switch
out of a washing machine.
The main thing I need is to interface the gauge with an existing fuel
monitoring system we make. The fuel system is accessed via the mobile phone
network. The user would like to be able to take a reading of the gauge, and
do an approximate calculation of how much fuel they have left, so that they
can order the correct amount. I know that ultrasonics etc can be used but a
simple gauge and and adc converter or a digital output from the gauge would
be nice.
Chris
Sent: Wednesday, May 30, 2001 7:16 PM
Subject: Re: [noparse][[/noparse]basicstamps] Pressure sensors...
> Do you just want to know when the tank is getting low? If so, one of the
and
approx
> from the same email address that you subscribed with. Text in the Subject
>Thanks Rodent,
>be nice.
>Regards,
>Chris
Hi Chris -
Motorola has a whole line of sensors, with pressure sensors among them.
Take a look here at the main sensors page, and drill down as needed:
http://mot-sps.com/sensors/
Hope that gets you started.
Bruce Bates
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
manufactured an overfill alarm that used this sensor. You have two tubes
that hang down into the tank, a short one as a reference, the other one
longer, cut at the high level plus about 3 inches. As the fluid level rises,
it reaches the longer tube and compresses the air in the tube. The sensor
detects the difference in pressure between the two tubes and triggers an
alarm.
Morrison Brothers manufactures a clock gauge with a setable contact -- also
for overfill, but usable for a low-level alarm. Morrison also makes a 1018
gauge that monitors the tank level continuously, but these are expensive.
This is esentially a large version of their clock gauge / float with an
encoder wheel indicating the absolute position of the float.
Does your fuel system not have a totalizer for the tank? I would think you
could maintain a basic tank inventory with this, as long as the customer
could remember to add deliveries to the total.
phone
and
they
a
would
The 'inventory' method has been suggested, the user has around Aust $4000
worth of measuring equipment on the tank, but for some reason does'nt like
the idea of having to calculate the balance (I guess he could be responsible
then if he gets it wrong !!). I will do some more searching for 'pressure
transducers' as another reply suggested. I thought I would throw the
question at the group because there are people from all walks on this group.
Thanks for your help,
Chris
responsible
group.
