Anyone know of cheap ground moisture meters ???
Hi All!
I am wanting to investgate the ability to measure the ground moisture
content in my garden remotely [noparse]:)[/noparse] ... ideally I can have a moisture sensor /
BS2 / RF unit / Solar panel that will send the data to the PC in the house.
The part I am unsure of is the moisture meter ... I want to bury them in the
ground all around my garden (maybe 20-30 of them) and then make a central
A/D - controller that will read them.
Does anyone have any good pointers to any cheap and dirty moisture meters
(if they are very expensive I will never get it past the budget committee
(wife))..... any links will help though even to expensive meters ....
Thanks!
John Ledford
Thanks!
John Ledford
At 06:31 PM 5/29/01 -0500, you wrote:
>Hi All!
>Thanks!
>John Ledford
>from the same email address that you subscribed with. Text in the Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Roger Edberg
roger@industrialartist.com
http://www.industrialartist.com
also:
Technical Tree Service
being the RC resistance element. Having AC instead of DC across the
moist metal probes will reduce corrosion.
At 5:57 PM -0700 5/29/01, Roger Edberg, you wrote about Re:
[noparse][[/noparse]basicstamps] Anyone know of cheap ground moisture:
>Gypsum blocks with leads embedded are used for this purpose. They
>vary inresistance with moisture. They are cheap, but I'm not sure
>where you get them. Call local University Ag research irrigation
>specialist?
> >Hi All!
\ / \ / \ N / \ C / \ S / \ S / \ M / \ / \ /
Chuck Britton Education is what is left when
britton@n... you have forgotten everything
North Carolina School of Science & Math you learned in school.
(919) 286-3366 x224 Albert Einstein, 1936
>Thanks!
>John Ledford
Hi John,
Here are a couple of links for soil moisture measurement and science:
http://www.sowacs.com/ ' sources, theory, wow
http://www.pedosphere.com/contents.cfm ' extensive tutorials
Here is a '555 circuit for AC isolated conductance measurements
http://www.emesystems.com/OWL2face.htm#conductivity
This is similar to the circuit in unit 5 of Earth Measurements.
http://www.emesystems.com/EarthM/em5.pdf
Gypsum blocks can be molded in a plastic film can around stainless
steel screws held in the lid.
Tensiometers are the way to go if you want to soften up the budget
committee for the cheaper stuff...
http://www.emesystems.com/OWL2face.htm#Irrometer
-- regards,
Thomas Tracy Allen Ph.D.
mailto:tracy@e...
about 1/8 in. diameter, and put them in pairs through a standard pipe
fitting with some epoxy to hold them in. Either threading or flattening the
top of each rod made it possible to connect them. A simple comparator
circuit with a low-current DC supply (almost any voltage will work - but I
seem to remember using 12V) gave good results. We put 12V on one rod, and
measured the level on the other rod, which was about 1/8 inch away. The
trick was determining at which point you wanted to be told the soil was dry.
They were pretty reliable and consistent (and inexpensive).
Chris
> From: John Ledford [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oalG3v39-efstoEHTnGLDYX8N5fVJ7uK-jMXJjbVBmsKVVHMWNQ0f-UUB4CUJzps2Pg4MSBRFviSok-1R9cx]john@k...[/url
> Sent: Tuesday, May 29, 2001 7:32 PM
> To: Basic stamps
> Subject: [noparse][[/noparse]basicstamps] Anyone know of cheap ground moisture
> meters ???
> Hi All!
> moisture sensor /
> PC in the house.
> bury them in the
> make a central
> moisture meters
> budget committee
> Thanks!
> John Ledford
