74LS193 to BS2
Mark-
Unless there's more code you're not showing, looks to me like you
never set I/O's 0, 1, 2 and 3 to output mode, hence setting OUTA to
whatever asserts nothing on those pins. Maybe set up all your DIRS
at start of program, or at least add:
dira = %1111
Steve
On 27 May 01 at 19:34, auto106947@h... wrote:
> Hi all,
> Anyone got any tips as to why my code here won't count?
> Keep getting zero...
dira = %1111
Steve
> Hi all,
Keep getting zero.
TIA,
Mark
'Count with 74LS193 and BS2
cntr var word
'clear '193
dir4 = 1 'set it up to pulsout high.
pulsout 4, 1000 '10k pullup resistor to +5v and BS2 pins 4 & 5
'and 11 Load and 14 Clr on the '193
'set data lines up with count by 13, %1101 is 13
outa = %1101
'load data into '193
out5 = in5 'set it up to pulsout low.
pulsout 5, 1000
pause 100
'start counting pulses, pulses are 25usec low true.
count 6, 1000, cntr
debug "count = ", dec cntr, cr
end
