HD44780 Hitachi 1x16 LCD — Parallax Forums
edited 2001-05-29 13:53 in General Discussion
Hi all,
I am trying to wake up a HD44780 LCD, 1 line of 16 characters
connected to a BS2 sx.
The module is a Powertip 1601, for wich very few information
can be found on the net. The technical sheet is not informative
at all.
I wrote the program hereunder and the only result that I got
was to black the first 8 characters of the display.
Note that the debug instructions are only for verification.
Can anybody help?
Many thanks in advance
ECO
'BS2sx to HD44780 LCD, using 4+2 pins
pin0 var OUTL.bit0·'LCD bit 4
pin1 var OUTL.bit1·'LCD bit 5
pin2 var OUTL.bit2·'LCD bit 6
pin3 var OUTL.bit3·'LCD bit 7
rsel var OUTL.bit4·'Select, 0=instr. 1=char
enab var OUTL.bit5·'LCD enable = 1
·················· 'R/W = Vss
char var byte··· ··'character to write
flag var byte···· ·'bit4 0=instr. 1=char.
init:
DIRL = %00111111···'6 LSB = outputs
pause 40
flag = %00000000···'instruction flag
OUTL = %00000011·· 'Initialize by
pulsout enab,60··· 'sending this pattern
pause 6······ ···· '4 times for 40 µS
pulsout enab,60··· 'separated with 5 mS
pause 6
pulsout enab,60
pause 6
pulsout enab,60
pause 6
OUTL = %00100100·· 'Function set:4bits,1 line,5*10 dots
pulsout enab,60··· 'send this pattern
pause 6
pulsout enab,60· ··'3 times for 40 µS
pause 6
pulsout enab,60
pause 6
char = %00000100
gosub writ
char = %00000110· ·'set increment,no shift
gosub writ
char = %00000001·· 'clear the display
gosub writ
flag = %00010000 ··'character flag
loop:
serin 16,240,[noparse][[/noparse]char]·'get a character from PC
debug HEX char
gosub writ··········'write it on LCD
goto loop···········'redo
writ:
OUTL = flag|char.highnib 'put high nibble in output
debug " ",HEX OUTL
pulsout enab,60····· ··· 'enable for 40µS
pause 6
OUTL = flag|char.lownib· 'put low nibble in output
debug " ",HEX OUTL
pulsout enab,60··········'enable for 40µS
return
    edited 2001-05-28 15:49
    Steve
    See the code below corrected and streamlined.
    Thanks to your advice it is now 90% OK.
    The only remaining problem, for wich I don't find answer in the documents,
    is that it writes only 8 characters although the module is clearly made for 16
    characters on one line. I miss perhaps a command?
    Thanks for your help (If you have time!)
    ECO
    'BS2sx to HD44780 1x16 LCD, using 4+2 pins
    'BS2sx· to·LCD
    'bit0····· pin11 = bit4
    'bit1····· pin12 = bit5
    'bit2····· pin13 = bit6
    'bit3····· pin14 = bit7
    'bit4····· pin04 = select
    'bit5····· pin06 = enable
    '········· pin05 = R/W = Vss
    '····· ··· pin01 = Vss
    '····· ··· pin02 = Vdd
    '····· ··· pin03 = contrast
    char var byte··'character to write
    flag var byte··'bit4 0=instr. 1=char.
    init:
    DIRL = %00111111··'6 LSB = outputs
    pause 500
    flag = %00000000··'instruction flag
    OUTL = %000011····'Initialize by
    pulsout 5,50···· ·'sending this pattern
    pause 5······ ··· '3 times for 40 µS
    pulsout 5,50
    pulsout 5,50
    OUTL = %0010····· 'Function set:4bits
    pulsout 5,50··
    char = %00001101··'disp on,cursor off,blink on
    gosub writ
    char = %00000110··'set increment,no shift
    gosub writ
    clear:
    char = %00000001··'clear the display
    gosub writ
    char = %00000010··'cursor home
    gosub writ
    flag = %00010000··'character flag
    loop:
    serin 16,240,[noparse][[/noparse]char]···· 'get a character from PC
    if char=$0D then clear··'if CR then clear screen
    gosub writ··············'write it on LCD
    goto loop··· ··· ··· ···'redo
    writ:
    OUTL = flag|char.highnib··'put high nibble in output
    pulsout 5,50··· ··· ··· ··'enable for 40µS
    OUTL = flag|char.lownib···'put low nibble in output
    pulsout 5,50····· ··· ··· 'enable for 40µS
    return
    To: "ECO" <ecourt@belgacom.net>; <basicstamps@yahoogroups.com>
    Sent: dimanche 27 mai 2001 00:32
    Subject: Re: [noparse][[/noparse]basicstamps] HD44780 Hitachi 1x16 LCD boundary="----=_NextP
    > ECO-
    > There's a problem in the way you're using PULSOUT
    > Regards,
    > Steve
    edited 2001-05-28 15:54
    Hi ECO,
    Many 1x16 LCDs are actually physically similar to a 2x8 LCD screen
    that has the second row moved up into the first line (after character
    8). Even though there are 16 characters on the first line, you need
    to treat characters 9-16 as if they were the first 8 characters of
    the second line.
    I hope this helps! Good luck with your project!
    --Jeff Wallace
    * Add a RTC, 256k EEPROM and an I2C bus to your BS2
    http://www.high-techgarage.com/products/timekeeper.php
    --- In basicstamps@y..., "ECO" <ecourt@b...> wrote:
    > Steve
    documents,
    made for 16
    > Regards,
    > ECO
    > 'BS2sx to LCD
    > 'bit0 pin11 = bit4
    > 'bit1 pin12 = bit5
    > 'bit2 pin13 = bit6
    > 'bit3 pin14 = bit7
    > 'bit4 pin04 = select
    > 'bit5 pin06 = enable
    > ' pin05 = R/W = Vss
    > ' pin01 = Vss
    > ' pin02 = Vdd
    > ' pin03 = contrast
    > char var byte 'character to write
    > flag var byte 'bit4 0=instr. 1=char.
    > init:
    > DIRL = %00111111 '6 LSB = outputs
    > pause 500
    > flag = %00000000 'instruction flag
    > OUTL = %000011 'Initialize by
    > pulsout 5,50 'sending this pattern
    > pause 5 '3 times for 40 µS
    > pulsout 5,50
    > pulsout 5,50
    > OUTL = %0010 'Function set:4bits
    > pulsout 5,50
    > char = %00001101 'disp on,cursor off,blink on
    > gosub writ
    > char = %00000110 'set increment,no shift
    > gosub writ
    > clear:
    > char = %00000001 'clear the display
    > gosub writ
    > char = %00000010 'cursor home
    > gosub writ
    > flag = %00010000 'character flag
    > loop:
    > serin 16,240,[noparse][[/noparse]char] 'get a character from PC
    > if char=$0D then clear 'if CR then clear screen
    > gosub writ 'write it on LCD
    > goto loop 'redo
    > writ:
    > pulsout 5,50 'enable for 40µS
    > OUTL = flag|char.lownib 'put low nibble in output
    > return
    > From: "S Parkis" <parkiss@e...>
    > To: "ECO" <ecourt@b...>; <basicstamps@y...>
    =_NextP
    > > ECO-
    > > Regards,
    > > Steve
    edited 2001-05-28 16:28
    [font=arial,helvetica]In a message dated 5/28/01 10:10:31 AM Central Daylight Time,
    ecourt@belgacom.net writes:
    16
    Your LCD is actually a 2x8 LCD, physically configured as a single-line
    display. ·This are a really big headache. ·In order to write the the other
    half of the display, you need to configure the LCD in multi-line mode and
    then write to the second line.
    -- Jon Williams
    -- Dallas, TX
    [/font]
    Steve, Jon and Jeff
    Many thanks for your help.
    For everybody:
    Take note of this code, to avoid 8 hours of frustration.
    Regards
    ECO
    'BS2sx to··· LCD
    'bit0··· ··· pin11 = bit4
    'bit1··· ··· pin12 = bit5
    'bit2··· ··· pin13 = bit6
    'bit3··· ··· pin14 = bit7
    'bit4··· ··· pin04 = select
    'bit5··· ··· pin06 = enable
    '··· ··· ··· pin05 = R/W = Vss
    '··· ··· ··· pin01 = Vss
    '··· ··· ··· pin02 = Vdd
    '··· ··· ··· pin03 = contrast
    char var byte··· 'character to write
    flag var byte··· 'bit4 0=instr. 1=char.
    indx var nib
    init:
    DIRL = %00111111··· '6 LSB = outputs
    pause 500
    OUTL = %000011······ 'Initialize by
    pulsout 5,50··· ··· 'sending this pattern
    pause 5··· ··· ···· '3 times for 40 µS
    pulsout 5,50
    pulsout 5,50
    OUTL = %0010··· ··· 'Function set: 4bits
    pulsout 5,50
    char = %00101000··· 'set for 2 lines or 16 characters
    gosub comm
    char = %00001101··· 'disp on, cursor off, blink on
    gosub comm
    char = %00000110··· 'set increment,no shift
    gosub comm
    clear:
    char = %00000001··· 'clear the display
    gosub comm
    loop:
    char = %00000010··· 'cursor home 1st block
    gosub comm
    indx = 0
    for indx = 0 to 7
    serin 16,240,[noparse][[/noparse]char]··· 'get a character from PC
    gosub writ··· ··· ··· 'write it on LCD
    next
    char = %11000000······ 'cursor home 2nd block
    gosub comm
    indx = 0
    for indx = 0 to 7
    next
    goto loop··· ··· ···· 'redo
    comm:
    flag = %00000000······ 'instruction flag
    writ:
    pulsout 5,50 ··· ··· ··· 'enable for 40µS
    pulsout 5,50··· ··· ··· 'enable for 40µS
    flag = %00010000··· ··· 'character flag
    return
