Allegro UCN5804 — Parallax Forums
Allegro UCN5804
edited 2001-05-30 02:01 in General Discussion
Anyone else here used a UCN5804? It's a stepper motor controller
in a 16-pin DIP package. Pretty easy to interface to a Stamp. You
really only need 2 pins: step and direction.
Data sheet can be found here:
http://www.allegromicro.com/datafile/5804.pdf
I've been playing around with one for a while now. Seems to work
fairly well. Not as sophisticated as the LittleStep-U module but
you can't beat the price (about $4).
Anyway, wanted to see if anyone else had tried these and what sort
of experiences they'd had.
SD
| Steve DeGroof (http://degroof.home.mindspring.com/) |
    edited 2001-05-25 03:08
    I use them and they work great!
    >SD
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    Roger Edberg
    roger@industrialartist.com
    http://www.industrialartist.com
    also:
    Technical Tree Service
    edited 2001-05-25 03:52
    What's the highest step rate you've gotten out of them? I've been
    experimenting with them and so far I haven't been able to get more
    than 100 steps/second without slipping.
    I suspect it's because the stepper motors I'm using are too large
    (too much inertia). I've got a couple of smaller motors on order.
    I'll have to see how they do.
    SD
    edited 2001-05-25 13:51
    Hey there is an mc3479p, made by motorolla, that works very well to. All
    you need is the step and direction as well. The outputs are also clamped to
    protect them from the motors coils.
    Sent: Thursday, May 24, 2001 9:52 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Allegro UCN5804
    > SD
    edited 2001-05-26 00:53
    When I start to get skipped steps as I increase frequency, I've assumed (maybe incorrectly) that the motors did not have the torque to keep up with the steps.
    The way I've got one setup geared, it takes 610 steps/in., and it will run about a five pound load at 30 in/min reliably. So that's (610*30)/60 or about 305 steps/sec.
    Roger
    >SD
    Roger Edberg
    also:
    edited 2001-05-29 20:00
    >with the steps.
    >Roger
    Roger,
    There are several reasons your stepper may be erratic. You're right about
    not having enough torque. Also you could be at
    the steppers resonant frequency. Steppers will miss steps and even step
    backward/forward in this region. Half stepping
    improves performance through the resonant frequency and micro stepping
    usually eliminates it. Don't use "wave" drive which
    powers only 1 phase at a time. The best torque is given when a 2 phase
    step sequence is used, 2 phases on, 2 phases off.
    If your doing this make sure you start the stepper at a step rate above its
    resonant frequency. Last, your top speed may be
    limited by the voltage your using. Powering a 5 volt 1 amp per phase
    stepper motor with 5 volts will limit speed to about 400
    Hertz. Running the same exact motor at 24 volts with a limiting resistor to
    absorb 19 volts when 1 amp flows through it
    ( the stepper still sees 5 volts at 1 amp max ) will increase speed to the
    2000 - 3000 hertz step rate. Rates higher than this
    require micro stepping. If you knew all this, oh well, never mind!
    Greg
    Good info! Thanks!
    >>with the steps.
    >>Roger
    >Roger,
    >Greg
    Roger Edberg
    also:
