BS2SX program download via phoneline
Peter-
I think you would ultimately regret attempting to crack this nut by
driving the remote location directly from the Stamp editor program
via modem (too many things going on simultaneously with critical
timing requirements). However, this ought to be do-able today if
you're willing to break the task up into a sequence of sub-tasks:
- write the program update at location 'A'
- save the program's token image to a disk file at 'A'
- transmit the image file via modem to remote location 'B'
- invoke program at 'B' to load revised tokens into Stamp
There are a few programs floating around now (search archives for
"token") that can save BS2* programs in their tokenized form and
later program a Stamp from that token image.
Alternatively, a customized version of these PC programs could be
created to handle the modem communications, the PC-Stamp programming
protocol and relay the tokens in real time. This could even be
implemented as a customized Stache chipset so that no PC (or
operator) is needed at the remote site.
Steve
On 25 May 01 at 9:53, Peter Verkaik wrote:
> ...I would like to be able to reprogram s Stamp
> from a remote location for software updates.
Steve
> Do I understand correctly this customized stache would just receive
> the tokens from the modem and relays them, using the proper
> protocol, to the stamp?
Essentially, yes, with a little error detection and recovery to
minimize comm link problems.
> This stache would require 2 serial ports then.
Agreed. That's one of the "customized" features I envisioned,
although the "serial port" from the chipset to the Stamp would look a
lot like four wires/traces from a DIP chip to your Stamp.
Steve
Has anyone ever tried and succeeded in
programming a BS2SX via an external modem
without the aid of a PC running PCAnywhere
ur sortlike software?
Any suggestions welcome.
Greetings peter.
which is like having a serial cable between your PC and the stamp. You can
get Radio modems to work over long ranges (50km) but you cannot have any
flow control.
From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lGRUKXyWXp4tekPkg7DBWEt2GpyvUozMBBlj_qvj8HYVME__toiNyPsVUJsafAZPVjqiHFaT21ehIhVRB335_g]bvbates@u...[/url
Sent: 25 May 2001 12:51
Subject: Re: [noparse][[/noparse]basicstamps] BS2SX program download via phoneline
At 5/25/2001 Friday 03:53 AM, Peter Verkaik promulgated:
>Hi everyone,
PC-Anywhere and other similar programs require the PC software to
running at the HOST and REMOTE sites. Thus, the STAMP can't run the
software.
You may want to take a look at Tracy Allen's STACHE. It can be found on the
Parallax website [noparse][[/noparse] http://www.parallaxinc.com ] and on Tracy's web site at
[noparse][[/noparse] http://www.emesystems.com/stachedat.htm ].
>Hope that helps.
>Greetings peter.
>Regards,
Bruce Bates
>Hi everyone,
running at the HOST and REMOTE sites. Thus, the STAMP can't run the software.
>Hope that helps.
>Greetings peter.
>Regards,
Bruce Bates
>It depends on how remote you are taking about. I am using some radio modems
>flow control.
Distance is (or should be) not an issue as I want to call in on a regular
phoneline.
So I have a modem in autoanswer mode at the Stamp site, and a PC with modem
at my location. I do not just want to receive and send data: I want to
reprogram
the Stamp, i.e the ATN (=DTR) line must be remotely controlled also.
Can this be done?
>software.
Obviously, but the PC at the stamp site is connected to the phoneline, while
the
Stamp is connected to a serial port. Using 'Remote Control' mode I can run
any
software on the remote PC, including the Stamp editor, as if I were working
at
the stamp site PC. Program download to the Stamp is then no problem, but it
requires a PC.
The STACHE is no option as it still requires my (or someone else) physical
presence at the
stamp site. This I hope to eliminate.
Any more suggestions welcome.
Greetings peter.
>Hi Okkie and Bruce,
> >flow control.
>phoneline. So I have a modem in autoanswer mode at the Stamp site, and a
>PC with modem at my location. I do not just want to receive and send data:
>I want to
>reprogram the Stamp, i.e the ATN (=DTR) line must be remotely controlled also.
>Can this be done?
I'm doing this from past memories of how PC-Anywhere works, but I think it
may work. I'd have to look it up to be sure, but I THINK you can control at
least
some of the hardware from the "far" end.
> >software.
>the Stamp is connected to a serial port. Using 'Remote Control' mode I can run
>any software on the remote PC, including the Stamp editor, as if I were
>working
>at the stamp site PC. Program download to the Stamp is then no problem, but it
>requires a PC.
There MAY be timing issues here. It's hard to tell without actually trying it,
but I think I could make a case either way. If the ports DON'T conflict
time-wise
ergo, the "far" PC is dormant during the Stamp programming process, it
seems as though it may work. The problem is - I'm not sure that's possible.
As I recall
the screen data automatically comes back, and may cause problems. Let's think
this out a bit ....
If this were a batch process - all data is sent to the far end first, and
then a .BAT file were fired off to FEED the Stamp Editor. and the screen
data was SPOOLED (which I believe can be done). you may well be able to
accomplish it.
>presence at the stamp site. This I hope to eliminate.
>Initially I didn't realize there was an available port.
I'll see if I can find my PC-Anywhere dox to investigate further.
>Greetings peter.
>Regards,
Bruce
While you get the remote control (e.g. PCAnywhere) software issues worked
out, you might want to review the message from Klaus Zahnert a little
earlier in the month, quoted next.
Daniel McGlothin
--<Start of Quoted Message>--
From: Klaus Zahnert [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QTf_NxNUD_g2UyAcwocRwZPs_lgGtnOi3_df2NEHuvrCyqw6ZfQnz43gHKfb3dlZRKoJw9mW2glJrA]kzahnert@d...[/url
Sent: Wednesday, 16 May 2001 12:01
Cc: ckuehnel@i...
Subject: [noparse][[/noparse]basicstamps] portable tokens for BS2SX-IC
Dear Stampers,
to update programs in remoted BASIC Stamps without giving the
PBASIC-sourcecode to others, often wanted to avoid manipulation and keeping
hidden the programming ideas. Solutions given last time are from Tracy
Allen: "STACHE" and Steve Parkis : "GETOKEN/ PUTOKEN".
Now we offer for test and evaluation the "TOKEN-CATCHER" and
"TOKEN-PUSHER", we made
to use with the VB6-Library on WIN9x. ..WIN2000. Free download from the
website of
Claus Kuehnel with http://www.ckuehnel.ch. Call his nice website, then go
to Microcontroller - Support | BASIC Stamp | TOK_CP08.ZIP. (179.286 kByte).
Yes, It's free up to now to get your experience with it. Any response
(actual problems also) with mail to kzahnert@d..., please.
I don't like unwanted long attachments to mails, but with a attached picture
of 25 (!) kByte you see a global scheme. Never will be without patience for
this,
I hope.-
Have fun and success ! Regards Klaus Zahnert
From: Peter Verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8nku0Jirm6-Ge3cHcFVa-_P9DYRBJ7n8iwfiEGJRUEWrh01gfaTDqTnT85EhylYej4ZvJhF5p2jnCFv028Fy2aJcqg]peterverkaik@b...[/url
Sent: Friday, 25 May 2001 03:53
Subject: [noparse][[/noparse]basicstamps] BS2SX program download via phoneline
Hi everyone,
Greetings peter.
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
>least
I do not want to use PCAnywhere. I merely wanted to mention the easy way.
Are the modem's handshake lines RTS and DTR controlled exclusively
by the modem? Or can they be set from 'the phone side' so to speak?
it,
>time-wise
>As I recall
think
>this out a bit ....
>accomplish it.
I know it works. I must send the new stamp source file using file transfer
mode.
Then open the stamp editor with the new file and execute the run command (on
the remote PC).
The run command gives hardly any screen changes so there is hardly any data
sent
back to me. I used the same technique to control a RS232 motorcontrolled
camera
from a remote site.
But the question still stands; can it be done WITHOUT THE PC, i.e just
a modem connected to the stamp program port?
Or is the only possibility to write some bootloader, exchanging data, and
let the stamp
reprogram itself by overwriting its eeprom locations. The data could be
generated using
TOKEN-CATCHER from Klaus Zahndert.
Greetings peter.
This would still require a PC at the remote site!
These I wanted to use to tokenize the data.
Do I understand correctly this customized stache would just receive the
tokens from
the modem and relays them, using the proper protocol, to the stamp?
Anymore suggestions welcome.
Greetings peter.
If I remember correctly, the Stamp will place itself into 'download' mode if
rebooted while a serial connection is on (I suppose that means taking ATN
high, but I'm not too sure).
So, it should be simple to get the Stamp to answer the phone call, establish
the data connection, and while the connection stays on, reset itself, thus
placing it in 'download' mode.
Then, via the data connection established, you just have to upload the new
code.
Cheers,
Mensaje original
> De: Peter Verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Lrc7YwtFNf0RZEy1fo0-94jVS3nX-1WKXa1MuZk7PQ_os9aDK83xxFwvQeVe_8TSjhOyaf6sXLuqHq7-2BeFjAif1Q]peterverkaik@b...[/url
> Enviado el: viernes, 25 de mayo de 2001 16:09
> Para: basicstamps@yahoogroups.com
> Asunto: [noparse][[/noparse]basicstamps] RE:BS2SX program download via phoneline
> Hi Bruce,
> I think it
> control at
> >least
> actually trying
> it,
> >time-wise
> that's possible.
> >As I recall
> think
> >this out a bit ....
> >accomplish it.
> mode.
> command (on
> the remote PC).
> hardly any data
> sent
> camera
> from a remote site.
> let the stamp
> generated using
> Greetings peter.
>Hi all,
>code.
The Stamp doesn't need to answer and establish a connection; the modem
alone does that. And you can tap into the CD light (or equivalent) on the
modem to trigger a Stamp reset. This light comes on when a connection is
established. I'm not sure the modem will satisfy all the Stamp's needs,
but it should be able to satisfy the ones above with a tiny bit of added
circuitry - a one-shot fired off the CD light to reset the Stamp.
Jim H
if
establish
>code.
Could it be that simple? Just connecting a stamp I/O pin to the stamp reset
and, after accepting the call, outputting a low on that pin would place
the stamp in download mode (this makes the I/O pin an input). Then all I
require
is a modified TOKEN-PUSHER program that would allow me to call out via a
modem?
Anyone any comments on this?
Greetings peter
>Hi Bruce,
> >least
That depends on the software and the application. Flow control can be done
in software or hardware. X-ON and X-OFF is an example of software control.
There are other methods as well.
>it, >but I think I could make a case either way. If the ports DON'T conflict
> >time-wise
> >As I recall
>think
> >this out a bit ....
> >accomplish it.
>mode. Then open the stamp editor with the new file and execute the run
>command (on the remote PC).
>sent back to me. I used the same technique to control a RS232 motorcontrolled
>camera from a remote site.
>let the stamp reprogram itself by overwriting its eeprom locations. The
>data could be generated using TOKEN-CATCHER from Klaus Zahndert.
I'm not familiar with the TOKEN-CATCHER, but it would surely be worth a look.
Without a PC the only way I can think to do it is with more than two wires
(RX, TX) and I don't believe that's your goal.
Other than that, I can't think of any way to do it - sorry.
>Greetings peter.
>Regards,
Bruce
>Greetings peter.
This would be quite easy if you are using a BS2P, instead of a BS2sx.
The reason is the new STORE command. You can have a program running
in bank 0, say, receive the tokens and WRITE them into another
program bank. Then RUN that other bank. You could bootstrap that
process to reprogram the entire BS2p.
It is possible to program a stamp with a "self-replacing" program.
Have you looked at Stamp I application note 16 (Keeping programs
private/self replacing programs)? The same trick can work in the
BS2, but it requires careful attention to the number of subroutine
calls in the program, so that the self-replacing part of the code can
be identical in both stamps.
As to invoking the stamp's built-in programming algorithm, the trick
is to generate the pulse on the ATN line while the RCV line is in the
BREAK state. You will need just a little bit of hardware to do
that--one half-monostable to detect the BREAK condition and from that
to trigger another half-monostable to generate an ATN pulse. It can
be done with a CD4093 chip. Then your PC program needs only generate
the long BREAK before sending tokens according to the protocol that I
have outlined on my web site.
<http://www.emesystems.com/BS2clone.htm>
For that you could use an adaptation of the DOS program by Steve
Parkis, or the Windows progam by Klaus Zahnert.
-- regards,
Tracy Allen
mailto:tracy@e...
I would like the stamp to answer. I don't want any sudden resets because of
data storage structures in eeprom. I could connect the CD output to a I/O
pin.
Greetings peter
simply resets the Stamp with a pulse (that's why you can put a cap in the
line to stop "ordinary" terminal programs from resetting the Stamp). The
pulse has to be followed immediately by some line condition or characters,
but I don't know which.
You know Tracy's site has an example of one Stamp programming another. Maybe
you could modify that so you'd have a modem and one Stamp on the far end
who's sole purpose was to program the other Stamp (kind of a remote
Stache -- maybe Tracy would even make one of these).
Al Williams
AWC
* Connect a PS/2 keyboard to your next project:
http://www.al-williams.com/awce/pak6.htm
> From: Peter Verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dMVebUuujBaSq4PwJX7QJiZ1ujec6LnFVUi5HRKpF_pKzJiFlrX3oFAnUH0bu5Qvo0BOeH4gibMTLSmC6ZSaT97wDg]peterverkaik@b...[/url
> Sent: Friday, May 25, 2001 10:06 AM
> Subject: [noparse][[/noparse]basicstamps] RE: BS2SX program download via phoneline
> Hi mike,
> if
> establish
> itself, thus
> upload the new
> >code.
> stamp reset
> require
> modem?
> Greetings peter
reset
> require
> modem?
If the modem is truly unattended, you might wish to deal in some fashion
with "wrong number" phone calls to the remote stamp. Caller ID and
Call-back modems come to mind.
It goes without saying, of course, with remote (and presumably un-attended)
resetting of the controller, that all of the relevant human and machine
safety issues should be considered.
Daniel McGlothin
Do You Yahoo!?
>Hi Jum,
>pin.
Or you can AND the CD light with the output of an I/O pin so the Stamp is
never reset unless that pin is in a state inviting reset. You can trigger
only on a rising CD line but not a sustained one. You can do all sorts of
things with gates and latches external to the Stamp and Modem to get the
safety you want. I wasn't offering the complete and final solution. I'm
not even sure it is really workable, but it's an idea to play with at least
in your head.
Jim H
> because of data storage structures in eeprom. I could connect the
> CD output to a I/O pin.
OK, wacky idea: Use 2 PICs as a sort of serial-line relay. PIC 1
is at the transmission end and sits between the PC and the modem
(external modem). It passes all serial data through and also sends
commands based on the state of DTR. Pic 2 is at the receiving end
and sits between the modem and the actual Stamp. It receives all
data from the modem and responds to the commands by setting DTR.
For example:
- PC sets DTR high, sends 'abc', sets DTR low
- PIC 1 sends Esc 1, 'abc', Esc 0
- PIC 2 sets pin0 high, sends 'abc', sets pin0 low
- Stamp sees DTR go high, gets 'abc', sees DTR go low
Note: Esc characters would have to be sent as Esc Esc
It'd look something like this:
__ Tx ____ _____ _____ ____ 2 _____
|PC|----|PIC1|-|Modem| |Modem|-|PIC2|---|Stamp|
| |DTR | | | | | | | | 3| |
| |Rx |____| | |-//-| | |____| 1| |
|__| |_____| |_____| |_____|
You'd need to set up PICs that could simultaneously send
and receive serial data (i.e. pass-through and filter).
SD
I have been using the IIe also. The Memory map shows only the memory in use
for the file( 2k ) you are viewing at the top level( the tab on top ). Also,
if you want to use several files in a project, you need to make sure that all
of the default com port settings are specified to the one you are using. I
can't remember the exact menus these are under but there are at least two
places to make changes. My project kept trying to look for some of the files
via another port. After I fixed it, it is working fine.
Patty
>For example:
>SD
Not too wacky! I use a similar setup in my modem access data
loggers. Except the extra PIC is only on the Stamp end, not on the
PC end. The PIC monitors the data lines, but the data itself passes
through directly to the stamp lines (not through the PIC chip).
power;--<---;
__ Tx _____ ___|_ _|__ _____
|PC|
|Modem| | CD|--|PIC |-3|atn |
| | | | |Modem| | | |Stamp|
| |Rx | |-//-| |---o-|---2| |
o---1| |
It was originally a Stamp1 circuit for modem & autoanswer at a site
with only solar power. Normally, the modem is turned completely off.
The PIC (originally a BASIC Stamp I) detects the incoming ring, and
turns on the operating power to a Cermetek modem. The PIC then
monitors the CD line and waits for the carrier. When it detects
carrier, it resets the stamp, which wakes up, sees the flag from the
PIC and proceeds to await data. The PIC then monitors the data line,
and among other things, it detects a BREAK signal that can be sent if
necessary from the PC. (BREAK is when the transmit line is held in
an active state much longer than normal data framed by start and stop
bits. 0.3 second is a typical BREAK) When the PIC detects a BREAK,
it resets the stamp, to regain its attention if it is off busy in
some loop. The PIC also implements hardware reset of the modem,
which is much more reliable than software reset (+++ ATH). The
original BS1 code is on my web site.
This circuit would also work for Peter's application, for remote
reprogramming. The BS1 program, when it detects the BREAK, normally
delays until the BREAK goes away before it resets the Stamp. But if
it were to generate the reset immediately, that would put the Stamp
into programming mode. (Given that the PC went on to send the right
preamble, tokens and checksums.)
-- best regards
Tracy Allen
mailto:tracy@e...
Better still, take an output from the RING line, that every modem I know
has. This line changes state when an inbound call is detected. If the modem
supports standard Hayes commands (which most do) then sending ATA<CR> via
the modem's RX line should answer the call.
Cheers,
Mensaje original
> De: Peter Verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tzDZOuePYoArTDpOm0XOg_Tf1nG6GHEwJ-474ZhtsuaF0p8U868P-3bnRORk-Acsl5JsFT0iRWxOKbUFurY-Uta3]peterverkaik@b...[/url
> Enviado el: viernes, 25 de mayo de 2001 17:23
> Hi Jum,
> equivalent) on the
> because of
> pin.
> Greetings peter
mondo mini, but i am not sure. Look in parallax web catalog. I hope
this helps.
