EEPROM memory
Using the BSII, I am recording the position of a POT into eeprom. The
rcTime variable is a word (8 bits), then write this value into eeprom
using the write command. However, EEPROM does not store values more
than 255. Do you know how I can store full words rather than only
bytes into memory?
thanks
Al Najjar
bytes into memory?
thanks
Al Najjar
WRITE x, aWord.highbyte
WRITE x+1,aWord.lowbyte
and then reverse for the read...
Al Williams
AWC
* 8 channels of PWM:
http://www.al-williams.com/awce/pak5.htm
> From: brownstamp@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dGU3guoC5K5nRsGDjglu4ICtz-3M8VmKsAD7pjaaR9id54OieU8yboOiL1ho0HKVGEIua_a9EEdTvQ]brownstamp@y...[/url
> Sent: Wednesday, May 23, 2001 1:57 PM
> Subject: [noparse][[/noparse]basicstamps] EEPROM memory
> bytes into memory?
> thanks
> Al Najjar
It works but I am not sure if I am converting things correctly.
Here is what I am trying, I use the value 1000 (decimal) stored in
a word variable (x), I write the x.highbyte into location 1, x.lowbyte
into location 2 and then try to debug x, I get 232 which is only the
low byte!
I tried this also:
x var word
x= 1000
debug dec x.lowbyte
I get 232
debug dec x.highbyte
I get 3
Could you please what is going on and do I need to do any conversions
before or after spliting/combining bytes?
Many thanks again....
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> You need to store the two halves separately:
> Al Williams
> AWC
> > From: brownstamp@y... [noparse][[/noparse]mailto:brownstamp@y...]
> > To: basicstamps@y...
The
eeprom
more
> > bytes into memory?
> > thanks
> > Al Najjar
1000 decimal is 3E8 in hex. So that is a high value of $03 and a low value
of $E8.
3 is 3
and $E8 is 232
so that is correct!
When you reverse it:
x.highbyte=3
x.lowbyte=$E8
debug ?x
It should work fine.
Al Williams
AWC
> From: brownstamp@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dCtSYisKyzycBVJ5QfoXcQwVNwB9LGWQxltRJGcF-gmgqWo0TfoLUoY_196scrEVdcCq3YL8yy8jBFr5jDs]brownstamp@y...[/url
> Sent: Wednesday, May 23, 2001 8:02 PM
> Subject: [noparse][[/noparse]basicstamps] Re: EEPROM memory
> Thanks Al W.
Although I understand the concept, I cannot apply it correctly into my
code. I am sure there is a silly mistake as usual. Will keep hacking
at it until it works.
sincere thanks again
Al Najjar
> The trick is to think about the hex value.
value
> of $E8.
> 3 is 3
> and $E8 is 232
> so that is correct!
> x.highbyte=3
> x.lowbyte=$E8
> debug ?x
> Al Williams
> AWC
> > Thanks Al W.
x.lowbyte
the
(Early in the AM so forgive any syntax errors)
eeaddress var word
eeword var word
main: ' your code here
eeaddress=0
loop: ' still your code here
x=*$&(&#$@ ' whatever your code is
eeword=x
gosub writeword
eeword=eeword+1
if eeword>=100 then dumpit ' whatever your code is???
goto loop
dumpit: ' still your code
for eeaddress=0 to 99
gosub readword
debug dec eeaddress,":",eeword
next
goto main ' or whatever
' *** END OF YOUR CODE
' start subroutines
' These multiply the address by 2 so you store at
' 0=0, 1=2, 2=4, 3=6, etc.
writeword:
write eeaddress*2,eeword.lowbyte
write eeaddress*2+1,eeword.highbyte
return
readword:
read eeaddress*2,eeword.lowbyte
read eeaddress*2+1,eeword.highbyte
return
Does that help?
Al Williams
AWC
* Control 8 servos at once:
http://www.al-williams.com/awce/pak8.htm
> From: brownstamp@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=J9vb9xJdCS6zE5P5_QH26y6-9RgTWAC9kxCgCwzIF68gu6tXUnRlGd1Z_TvFmguzhjLGCdJT8n3yWt23aaM]brownstamp@y...[/url
> Sent: Wednesday, May 23, 2001 11:28 PM
> Thanks again!
> Al Najjar
> value
> > of $E8.
> > 3 is 3
> > and $E8 is 232
> > so that is correct!
> > x.highbyte=3
> > x.lowbyte=$E8
> > debug ?x
> > Al Williams
> > AWC
> > > Thanks Al W.
> x.lowbyte
> the
Should be:
debug dec eeaddress,":",dec eeword
Sorry!
Al Williams
AWC
