Pak man
Ok Al,
You got me hooked on buying some IC's off of you but I need some help I deciding on what I should get.
First, You seen what math problems I am using, I don't need any more memory, and those two problems are all I am using.
seconded, I need to count a pulse for 1000mS, and do a PULSIN of a low, and monitor 4 buttons, all at the same time ( or close to it ).
I am trying to make my project ( ADIC ) faster. Also can the PAK's run off one crystal ( will not be using the ceramic resonators )? And what type of crystal do you recommend?
TC
TC
A PAK-I will do what you want math-wise. The PAK-II adds things like
sin/cos/tan/log/etc. which you don't need.
If I understand your pulse problems, you want a PAK-VII. It counts times and
edges on 8 channels at one time. So you count pulses, track time, read
pulses, and look at the buttons.
You can read all the manuals online.
Ordering a PAK soon earns you a free NetPorter CD too -- I can't recall when
that ends, but it is soon. You have to put a code on the order
(www.al-williams.com/awce for details).
Al Williams
AWC
* Floating point A/D (5 channels, 10 bit)
http://www.al-williams.com/awce/pak9.htm
From: Anthony Conti [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=b6yzLVDnDjvMHCtV6plu_i5NyqknmFJmc7NjLLMkb98jt_d9-wKo0os-2hg0wwY7o0KaFYn327M]aconti@n...[/url
Sent: Tuesday, May 22, 2001 7:34 PM
To: basic stamp
Subject: [noparse][[/noparse]basicstamps] PAK MAN
Ok Al,
TC
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
