VB6 to BS2 serin woes
[font=arial,helvetica]Hi everyone. I've been pulling my hair out on this problem
for the last couple of hours. I'm finally giving in and hope that
the "collective" can show me the error of my ways.
I'll bet it is something embarrassingly simple, but even after
going through the Stamp manual and two Stamp books, I
just can't see the solution, even though it's probably right in
front of me. ·:-(
I'm receiving data from a PC through pin0 on the Stamp 2.
The sample string is "@62409". The BS2 waits for the "@",
then places each of the following bytes into it's own variable
(char1, char2, etc). So far so good, the data is received and
debugged to a second PC. ·From there I want to convert the
five char variables into a single word. The code works fine if I
hardcode the variables (char1=6, char2=2, etc) - total will equal
62409. But the way this code is written, total equals 5913.
I imagine the problem might have something to do with receiving
the ASCII values for 6,2,4,0, and 9 instead of the actual number. (?)
Is there some sort of modifier that I may be overlooking?
char1 var byte
char2 var byte
char3 var byte
char4 var byte
char5 var byte
total var word
total=0
serin 0,16468,[noparse][[/noparse]wait("@"),char1,char2,char3,char4,char5]
total=char1*10000
total=total+(char2*1000)
total=total+(char3*100)
total=total+(char4*10)
total=total+char5
debug "Char1 = ",char1,13
debug "Char2 = ",char2,13
debug "Char3 = ",char3,13
debug "Char4 = ",char4,13
debug "Char5 = ",char5,13
debug "Total = ",dec total,13,10
Thanks guys!
Steve[/font]
front of me. ·:-(
char1 var byte
char2 var byte
char3 var byte
char4 var byte
char5 var byte
total var word
total=0
total=char1*10000
total=total+char5
Thanks guys!
Steve[/font]
Serin 0,16468,[noparse][[/noparse] wait("@"),dec total]
debug ?total
Or you could subtract "0" from each digit:
char1=char1-"0"
char2=char2-"0"
Yet another way would be to use an array, so you could write:
total=0
for i=0 to 5· ' 6 digits
· total=total*10
· total=total+char(i)-"0"
next
debug ?total
How's that?
Al Williams
AWC
* Connect your Stamp to the Internet.
http://www.al-williams.com/awce/netporter.htm
From: PicProgrammer@aol.com [noparse][[/noparse]mailto:PicProgrammer@aol.com]
Sent: Thursday, May 17, 2001 2:21 PM
Subject: [noparse][[/noparse]basicstamps] VB6 to BS2 serin woes
front of me. ·:-(
char1 var byte
char2 var byte
char3 var byte
char4 var byte
char5 var byte
total var word
total=0
total=char1*10000
total=total+char5
Thanks guys!
Steve
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
[/font]
alw@al-williams.com writes:
<<Well, you could make the Stamp do it for you:
Serin 0,16468,[noparse][[/noparse] wait("@"),dec total]>>
As usual, you are correct Al. ·This was how I tried it the
first time around (dec5 total), but it wouldn't work. The BS2
and PC were communicating at 9600N81, with a dead simple
VB6 program (using MSCOMM) sending the string. I just tried
it without the WAIT modifier, and it works as it should. Looks
like the BS2 is just a bit too slow when using WAIT at 9600 with VB?
Oddly enough, when using WAIT, if I sent the string twice in a
row, it would work! Strange though that the BS2 would correctly
receive the data at the same rate when using 5 byte variables instead
of dec5.
When bumping the rate down to 2400, everything is just peachy.
Would you know if there is some sort of automagical intercharacter
pacing property available with the MSCOMM control?
<<Or you could subtract "0" from each digit:
char1=char1-"0"
char2=char2-"0">>
Doh!!!! (slapping forehead) ·See, I told you I would wind up
being embarrassed. LOL
Thanks Al! ···BTW, love the book. Any more titles on the horizon? :-)
Steve
[/font]
Glad you've enjoyed the book. Yes a couple of new books coming out within
the next few months. Probably see the first of them after the summer.
Al Williams
AWC
* Connect your Stamp to the Internet:
From: PicProgrammer@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IKNJhjb8N9EUiS1lWLP3QBEKNd2Hi5WttTW95AGk6hEXJiIB6CWHj5OQcXU3iCasJ7pn8jzJp83G9QwQ2w]PicProgrammer@a...[/url
Sent: Thursday, May 17, 2001 7:30 PM
Subject: Re: [noparse][[/noparse]basicstamps] VB6 to BS2 serin woes
In a message dated 5/17/01 3:50:23 PM Eastern Daylight Time,
alw@a... writes:
As usual, you are correct Al. This was how I tried it the
of dec5.
char1=char1-"0"
char2=char2-"0">>
Doh!!!! (slapping forehead) See, I told you I would wind up
Thanks Al! BTW, love the book. Any more titles on the horizon? :-)
Steve
Thanks Al, I'll give that a shot.
Serial BS2 comms just got a bit more interesting. Same hardware
setup as before - BS2 debugging to my desktop, and receiving data
on Pin 0 from a laptop). The laptop side is running W95 and Hyperterminal
(v. 595160). Connected at 2400N81. I was just using this setup to confirm
that the serial link was working, running this snippet of code:
loop:
serin 0,16780,[noparse][[/noparse]b1]
debug dec b1,13
goto loop
Should be simple enough, right? Not today it isn't. LOL
As long as I don't repeat any character more than twice in a row, all
is fine.
Pressing "ABBCDEFFG" correctly returns:
65
66
66
67
68
69
70
70
71
But on the third repetition of a character, b1 suddenly grows by 128.
Further repetitions of the same character alternate between b1 and b1+128.
Example, typing "AAAAAAA" results in:
65
65
193
65
193
65
193
etc.
Am I going nuts here??? :-(
<<Glad you've enjoyed the book. Yes a couple of new books coming out within
the next few months. Probably see the first of them after the summer.>>
Are any of these books stamp related? (hint, hint, hint)
Best regards,
Steve[/font]
I've been following this and would like to add a question. I
have a VB6 to BS2 program that sends single byte instructions to the BS2
board. Setup is serin 16, 84, [noparse][[/noparse]SerData].
Everything appears to be working except it doesn't appear that I
can send a hex 0, or NULL byte to the BS2. Anyone else have this
experience. Does this have something to do with the bit 16 setup to use
the same interface as the stampw.exe software uses for loading the
program in the BS2?
Thanks, Theron
work. If you are sending text, it won't work. That's a guess, but I'd bet a
few dollars on it.
Al Williams
AWC
* Connect your Stamp to the Net (or any serial device):
> From: Theron Wierenga [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MK-9MJH5b_96iF-YCTvWverrnWeGFY3PY0DOF-WHRk5pEXKoMI0iZyNLzxhHm5ANVP4U-gj29AgVz0cZS5JlXYlwg6T0fQ]twiereng@m...[/url
> Sent: Friday, May 18, 2001 10:10 AM
> Greetings all,
> program in the BS2?
> Thanks, Theron
