Newbie - Stamp2 - VB via Debug
Please forgive what I hope is a very silly question.
I have a BS2 connection through a serial port to COM 1.
Using Stamp2.exe, I have a program reading input from an LDR circuit every 2
seconds and outputing to DEBUG - works fine.
I have the Serial Port Complete code for the template application amended
with RThreshold = 1 to ensure that OnComm fires. Port is set to COM 1 and
Baud is 9600,8,n,1. However, OnComm never fires!
I can make OnComm fire if I set 'MSComm1.Output="BLAH"' and then open the
'Change Node Set Up' window and click OK, with the BLAH being echoed.
Obviously, I can't have Stamp2.exe and the VB App running at the same time,
how can I check that the program is running on the Stamp, or find out what
is going on? I'm not an EE and don't have LEDs and stuff available.
Any pointers gratefully received.
Duncan
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Duncan
I dont know the solution to the fireing of the event, but there is a
VERY usefull tool you can use to monitor the serial data that goes
through any port.
Go to http://www.win-tech.com/html/listen.htm and download the
listen32 version. You can monitor the port when the Stamp is running
and see that you are getting the right incoming data and make sure
that it is correct.
As for the VB side of things, I know you propably done everything I
am going to mention, but here's just a recap of the mscomm
functionality, just in case .... (out of the VB Help)
>Event-driven communications is a very powerful method for handling
>serial port interactions. In many situations you want to be notified
>the moment an event takes place, such as when a character arrives or
>a change occurs in the Carrier Detect (CD) or Request To Send (RTS)
>lines. In such cases, use the MSComm control's OnComm event to trap
>and handle these communications events. The OnComm event also
>detects and handles communications errors. For a list of all
>possible events and communications errors, see the CommEvent
>property.
>You can also poll for events and errors by checking the value of the
>CommEvent property after each critical function of your program.
>This may be preferable if your application is small and self-
>contained. For example, if you are writing a simple phone dialer, it
>may not make sense to generate an event after receiving every
>character, because the only characters you plan to receive are the
>OK response from the modem.
Also make sure that you opened the port (mscomm1.portopen = true) and
when your code ends, make sure you close the port again. Otherwise
the port sometimes end up being "unavailable" and you have to restart
the machine or reset the port (I think you can reset the port in
win2000 but not in prev OS's)
Hope this helped
Cheers
Okkie
circuit every 2
amended
COM 1 and
open the
echoed.
same time,
out what
> Duncan
___
Chris
Sent: Wednesday, May 16, 2001 5:04 PM
Subject: [noparse][[/noparse]basicstamps] Newbie - Stamp2 - VB via Debug
2
time,
> Duncan
I'll give it a try.
Duncan
--- In basicstamps@y..., okkie@i... wrote:
> Hi there Duncan
a
> through any port.
running
> that it is correct.
notified
(RTS)
trap
> >property.
the
it
and
restart
> Hope this helped
> Cheers
> Okkie
> circuit every 2
application
> amended
> COM 1 and
> open the
> echoed.
> same time,
> out what
available.
> > Duncan
> ___
I think that it may be already, but I'll check anyway.
Duncan
--- In basicstamps@y..., "Chris Anderson" <fes@g...> wrote:
> Make sure you have the mscomm1.inputlen set to 0
> Chris
> From: Duncan Spence <spence_duncan@h...>
> To: <basicstamps@y...>
circuit every
> 2
application amended
COM 1 and
open the
echoed.
same
> time,
out what
available.
> > Duncan
___
Any other ideas? A silly question, if I load a program through
stamp2.exe and then shut that application down, the loaded program
does stay running, doesn't it? What about after a power down?
Duncan
> Chris
circuit every
> 2
application amended
COM 1 and
open the
echoed.
same
> time,
out what
available.
> > Duncan
___
