Speech recognition for BOEbot
Stampers,
Any idea how to add speech activated command module
to Boebot ?
Need to implement at least 5 speech activated commands.
Thanks.
-Edward
to Boebot ?
Thanks.
-Edward
train it to respond to a couple of commands to turn on/off a LED. We are
new to the Stamp arena, and at first we did not understand the communication
protocol between it and the stamp - eventually we figured it out. They do
not have BS2 examples for their product.
> From: edwardong@a... [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=m_PVj6RBQMTYtEdqSQgWYEIm_qoqH27fPQLuks8t-Ni-ZdunqIN4jv5uu6aEHyo3IEZydBbgQLfBurqWlQ]edwardong@a...[/url
> Sent: Tuesday, May 15, 2001 9:41 PM
> Subject: [noparse][[/noparse]basicstamps] Speech recognition for BOEbot
> Stampers,
> to Boebot ?
> Thanks.
> -Edward
········How do youlike the Voice Direct 364 module?· Are the recognition results veryrepeatable?
Tim
At 08:29 AM 5/16/2001 -0500, you wrote:
train it to respond to a couple of commands to turn on/off a LED.·We are
new to the Stamp arena, and at first we did not understand thecommunication
protocol between it and the stamp - eventually we figured it out.·They do
> From:·edwardong@astec.com[noparse][[/noparse]SMTP:edwardong@astec.com]
> Sent:·Tuesday, May 15, 2001 9:41 PM
> To:···basicstamps@yahoogroups.com
>Subject:······[noparse][[/noparse]basicstamps]Speech recognition for BOEbot
>····· Stampers,
>··············Any idea how to add speech activated command module
>··············to Boebot ?
>··············Need to implement at least 5 speech activated commands.
>··············Thanks.
>··············-Edward·
> Your use of Yahoo! Groups is subject tohttp://docs.yahoo.com/info/terms/
Timothy Medema
CrystaLite, Inc.
3307 Cedar St.··················(425) 745-6000·· 800-666-6065
Everett, WA 98201···············Fax: (425) 257-0232
www.crystaliteinc.com···········timm@crystaliteinc.com
The information transmitted is intended only for the person or entity to whom it is addressed and may contain confidential and/or privileged material.· Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited.· If you received this in error, please contact the sender and delete the material from any computer.
it seems to require a lot to make it work.
During training, we had to "yell" into the mic at times for it to pick up on
the word we wanted to train. The documentation was not very good, and there
are no Stamp examples. Similar sounding words will make it through.
"Usually", it could pick up the word we said from 3 to 5 feet. Almost
always, it picked the word I said from the list of trained words. Because
of either our lack of Stamp programming skills, or the weirdness of how the
module communicates with the Stamp - our programs got quite lengthy.
Commands and responses are transmitted/received in byte clusters. Each byte
must be processed a bit at a time taking into consideration the state of a
single pin used to link it to the module. It can be made to respond to
single commands ( i.e. Left, Right, etc. ) or multiple word commands ( i.e.
Light / On, Motor / Off ).
We have put the recognition part of our robot on hold for the time being.
We thought it would be a cool project. It works, and for $50 it has been
okay. Right now we are working on wheels, motors, and the body. I want to
continue with the multiple word commands, so I will probably pick it back up
again in the future.
On a side note: I have a copy of John Iovine's book titled "Robots,
Androids, and Animatrons 12 Incredible Projects You Can Build!"
It has a small section about Stamps. It also has another section of Speech
Control. He uses a HM2007 "single-chip CMOS voice-recognition LSI circuit".
You might consider the book and/or the chip.
Good Luck,
Bryan Smith
> From: Timothy Medema [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TkOLYSlPZsYRO_7r16V_s1GjXzGLmrUf9oYHcBL0kW_2DvRz6rU0YIWF54eKJUAExudLdoz3Z6_i4OunIBgu]timm@c...[/url
> Sent: Thursday, May 17, 2001 1:55 PM
> Subject: RE: [noparse][[/noparse]basicstamps] Speech recognition for BOEbot
> Hi Bryan,
> How do you like the Voice Direct 364 module? Are the recognition
> results very repeatable?
> Tim
> You might try Voice Direct 364. We purchased the kit, and were able
> to
> We are
> communication
> They do
> > From: edwardong@a... [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_0n3oDYnM9mWWe5fMtQKfmvBi2c-hB73v_YUPgHNpPpPGXBHJpFvZLXY5-9R_aYAQodNzIL-iOK8Uw]edwardong@a...[/url
> > Stampers,
> > to Boebot ?
> commands.
> > Thanks.
> > -Edward
> <http://docs.yahoo.com/info/terms/>
> Timothy Medema
> CrystaLite, Inc.
> 3307 Cedar St. (425) 745-6000 800-666-6065
> Everett, WA 98201 Fax: (425) 257-0232
> www.crystaliteinc.com <http://www.crystaliteinc.com/>
> timm@c... <mailto:timm@c...>
> material. Any review, retransmission, dissemination or other use of, or
> entities other than the intended recipient is prohibited. If you received
> computer.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/>.
········Thanks forall of your input.
Much appreciated,
Tim
At 03:24 PM 5/17/2001 -0500, you wrote:
it seems to require a lot to make it work.·
During training, we had to "yell" into the mic at times for itto pick up on
the word we wanted to train.· The documentation was not very good,and there
are no Stamp examples.· Similar sounding words will make itthrough.
"Usually", it could pick up the word we said from 3 to 5feet.· Almost
always, it picked the word I said from the list of trained words.·Because
of either our lack of Stamp programming skills, or the weirdness of howthe
Commands and responses are transmitted/received in byte clusters.·Each byte
must be processed a bit at a time taking into consideration the state ofa
single pin used to link it to the module.· It can be made to respondto
single commands ( i.e. Left, Right, etc. ) or multiple word commands (i.e.
We have put the recognition part of our robot on hold for the timebeing.
We thought it would be a cool project.· It works, and for $50·it has been
okay.· Right now we are working on wheels, motors, and thebody.· I want to
continue with the multiple word commands, so I will probably pick it backup
On a side note:· I have a copy of John Iovine's book titled"Robots,
It has a small section about Stamps.· It also has another section ofSpeech
Control.· He uses a HM2007 "single-chip CMOS voice-recognitionLSI circuit".
Good Luck,
Bryan Smith
> From:·Timothy Medema[noparse][[/noparse]SMTP:timm@crystaliteinc.com]
> Sent:·Thursday, May 17, 2001 1:55 PM
> Subject:······RE:[noparse][[/noparse]basicstamps] Speech recognition for BOEbot
> Hi Bryan,
>········ How do you like theVoice Direct 364 module?· Are the recognition
> Tim
> ······You might tryVoice Direct 364.· We purchased the kit, and were able
> to
> ······train it torespond to a couple of commands to turn on/off a LED.
> We are
> ······new to the Stamparena, and at first we did not understand the
> communication
> ······protocol betweenit and the stamp - eventually we figured it out.
> They do
> ······not have BS2examples for their product.
> ······> From:edwardong@astec.com [noparse][[/noparse]SMTP:edwardong@astec.com]
> ······> Sent:Tuesday, May 15, 2001 9:41 PM
> ······>To:·· basicstamps@yahoogroups.com
> ······>Subject:····· [noparse][[/noparse]basicstamps] Speech recognitionfor BOEbot
>······>·····Stampers,
>······>··············Any idea how to add speech activated command module
>······>··············to Boebot ?
>······>··············Need to implement at least 5 speech activated
> commands.
>······>··············Thanks.
>······>··············-Edward·
> ······> Your use ofYahoo! Groups is subject to
> ······Your use ofYahoo! Groups is subject to
> Timothy Medema
> CrystaLite, Inc.
> 3307 CedarSt.·················(425) 745-6000·· 800-666-6065
> Everett, WA98201··············Fax: (425) 257-0232
>www.crystaliteinc.com<http://www.crystaliteinc.com/>
> timm@crystaliteinc.com <mailto:timm@crystaliteinc.com>
> computer.
Timothy Medema
CrystaLite, Inc.
