Problems with I/O pins on Basic Stamp II
I'm only able to receive an output voltage to P0, in which I have an
led and resistor connected to it. This works fine as the led blinks
on/off for the program that I wrote. but I get no output voltage
from the other I/O pins P1 - P15. Here's what my code looks like:
output 0 'make p0 an output
output 1 'make p1 an output (doesn't work for pins P1 - P15)
reblink:
out0 = 0 'turn on p0
out1 = 1 'turn off p1 (doesn't work for pins P1 - P15)
pause 1000
out0 = 1 'turn off p0
out1 = 0 'turn on p1 (doesn't work for pins P1 - P15)
pause 1000
goto reblink
I've rechecked all of the solder connects from P1 - P15
P.S. - I built the Basic Stamp II from a stamp kit
Any suggestions would be greatly appreciated.
Ty
reblink:
pause 1000
pause 1000
goto reblink
Ty
second delay before the next pin goes high, starting with pin 0 to pin 15.
a var nib
for a = 0 to 15
high a
pause 1000
next
> reblink:
> pause 1000
> pause 1000
> goto reblink
> Thanks,
> Ty
I'll give it a try!
Ty
--- In basicstamps@y..., "L .Gaminde" <lgaminde@t...> wrote:
> Try this first, this will make all pins high, one at a time, with a
one
pin 15.
> a var nib
> for a = 0 to 15
> high a
> pause 1000
> next
an
blinks
> > reblink:
> > pause 1000
> > pause 1000
> > goto reblink
> > Thanks,
> > Ty
