Strobe Flash Rate.....
Decrease charge capacitor value.(this will also decrease the flash
intesity)
Increasing flash rate may overheat the flash bulb, damaging it or even
exploding.
Raising the voltage seems be not pratical dued the need of change almost
all components that probably will not support higher voltages.
Be sure to safely discharge the capacitor (thru a resistor) before work
in this circut. Large hi-voltage capacitors used in a strobe may keept
lethal voltages for prolonged time.
ACJacques
Tim and Jo wrote:
> Group,
> I'm using a surplus camera flash unit as a strobe light in a BS2
> controlled project and I'd like to get it to charge faster so that I can
> increase the flash rate. Idealy, I'd like to flash the strobe about 8-10
> times per second. As it's designed, it takes about ten seconds to charge
> using a single AA battery as the power supply. What will it take to make it
> charge much faster? Is it simply a matter of increasing the supply voltage
> or is the charge time a function of the design?
> Any help is much appreciated,
> Tim
intesity)
exploding.
ACJacques
Tim and Jo wrote:
> Group,
> Tim
Tim
as lightbars or the hide-away strobe bulbs.
The opticom system to change the traffic lights when a fire truck approaches
flashes at least 8-10 FPS.
Check with Whelen, Federal Signal, and other manufacturers for more
specifications on the bulbs.
Jason
Sent: Saturday, May 12, 2001 2:14 PM
Subject: Re: [noparse][[/noparse]basicstamps] Strobe Flash Rate.....
> intesity)
> exploding.
> ACJacques
> Tim and Jo wrote:
> > Group,
8-10
charge
make it
voltage
> > Tim
