SERIN ASCII to DEC equivalent
Ok,
I'm trying to do math on the ASCII code of the inbound serial string. I find
my pattern point and load a 6 byte array with the next 5 characters. Then I
want to do some simple math to determine the value of the array. (Not enough
room to do pattern matching to another array)
Example
SerData VAR BYTE(6)
SerData(5) = 0
main:
SERIN 16,16780,[noparse][[/noparse]WAIT("0A0"), STR SerData\5]
' This gets the data and inserts it into the array.
'Now determine witch of the 6 possible strings it is
The 6 possible strings that can be stored in SerData are;
2B218
23219
2B21A
2B219
2321A
2321B
If I can use the ASCII code for each slot in the array and sum all the slots
I would end up with;
271
257
280
272
265
266
So my question is how do I get the ASCII code for each character in each
slot from the array?
temp = SerData(0) ''where temp = 50 because SerData(0) = "2"
Example
SerData VAR BYTE(6)
SerData(5) = 0
main:
2B218
23219
2B21A
2B219
2321A
2321B
271
257
280
272
265
266
If your curious
'{$STAMP OEM BS2}
SerData VAR BYTE(6)
SerData(5) = 0
bMatch VAR BYTE
i VAR NIB
main:
' Total the arrey slots
FOR i = 0 to 5
bMatch = bMatch + SerData(i)
NEXT
IF bMatch = 271 THEN drop1 'Receved 2B218
IF bMatch = 257 THEN drop2 'Receved 23219
IF bMatch = 272 THEN drop3 'Receved 2B219
IF bMatch = 265 THEN drop4 'Receved 2321A
IF bMatch = 280 THEN drop5 'Receved 2B21A
IF bMatch = 266 THEN drop6 'Receved 2321B
drop1:
HIGH 0
PAUSE 5000
LOW 0
GOTO main:
<snip>
