RS232 -> PC oddity
Hi all
I am using two stamp pins (BS2SX) for RS232 communication to a PC.
Data transmitted from the BS2 to the PC is flawless - Always.
Data transmitted to the BS2 from the PC is a bit hit and miss.
The BS2 might receive the first 5 bytes, sometimes 20 and then miss
a byte. It has no pattern that I can see and is driving me crazy.
My question is this :
Has anyone else encountered this ?
Could it be due to the BS2 not using true RS232 voltages ?
Should I be using a MAX233 anyway ?
Helllllllllp!!!
Regards
Steve Percy
Helllllllllp!!!
Regards
Steve Percy
I do this all the time, using a Max232, and haven't
had this problem.
Hope that helps
Russ
Sent: Thursday, May 10, 2001 10:25 AM
Subject: [noparse][[/noparse]basicstamps] RS232 -> PC oddity
| Hi all
| Helllllllllp!!!
| Regards
| Steve Percy
| Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
try 4800 and see what happens.
(Presuming you are using 9600)
Chris
Sent: Thursday, May 10, 2001 10:25 PM
> Hi all
> Helllllllllp!!!
> Regards
> Steve Percy
Your BS2sx can probably not follow the speed of your PC, especially
if you use SERIN formatters.
Try lowering your bad rate.
ECO
Sent: jeudi 10 mai 2001 16:25
> Hi all
> Helllllllllp!!!
> Regards
> Steve Percy
