Electronic Speed Control Help! — Parallax Forums
edited 2001-05-10 14:47 in General Discussion
Greetings list,
I have bought an Electronic Speed Control and hooked it up to my basic
stamp. It is essentially going to run two electric motors on a monster
truck.
I am trying to give it a pulsout to the pin number, but it is not responding
like a regular servo.
Does anyone have any suggestions?
Karl
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com
    edited 2001-05-09 23:58
    Some (most) speed controls use an opto-isolator in the inputs that
    requires low impiedance driving. Check with a scope to see the level of
    the pulse when connected. Use a buffer voltage follower to drive if
    needed.
    ACJacques
    Arch- Angel wrote:
    > Greetings list,
    > truck.
    > Karl
    edited 2001-05-10 00:13
    Might try setting the pin low, then doing the pulsout.
    > truck.
    responding
    edited 2001-05-10 14:20
    Do you have the correct pulse train?
    You need continually repeating pulses between about 1 and 2 ms, every
    20 ms... although the spacing isn't too critical.
    pm
    Yep My pin is set to 'low'
    Karl
    >From: Rodent <daweasel@s...>
    >Reply-To: basicstamps@yahoogroups.com
    >Subject: Re: [noparse][[/noparse]basicstamps] Electronic Speed Control Help!
    >Date: Wed, 09 May 2001 18:13:18 -0500
    > > truck.
    >responding
