Dallas Semiconductor DS1302
Would anyone happen to have some code on this time keeping chip. I
have the time of day and the day of the week squared away but am
having some difficulty with the month day and year. I am using this
to attach to a pressure reading and store about 30 of them so I will
no what day the readings were taken. Is this the best way to do this?
pressure reading every hour) you only need to know the start time and
the interval between readings. It would simplify the code, although
it would require more work to interpret the data.
If you set the DS1302 to use clock/calendar burst mode, you can
sequentially read the next 7 bytes, starting with seconds. If you can
get the the time and day, the month and year should be the same.
Parallax has created an App Note for the DS1302 and is available in
the downloads section. It has detailed code for reading and
formatting the data from the DS1302. (Check their downloads section).
A similar chip to the DS1302 is the DS1307 which is a 2-wire device.
I have created a tutorial for using the DS1307 chip at:
http://www.High-TechGarage.com/tutorial/ds1307.php. You may also be
interested in a BS2 enhancement (the TimeKeeper) which has a DS1307
and up to 256K EEPROM for data logging. Best of all, the TimeKeeper
fits underneath your BS2 and can be powered by the STAMP's voltage
regulator.
Good luck,
--Jeff Wallace
--Add a RTC, EEPROM and an I2C bus to your BS2
--www.high-techgarage.com/products/timekeeper.php
this
will
this?
