OT Xmitter Reciever
Hi All,
I'm looking for a Transmitter/Receiver setup that could take multiple
transmitters and be received by one receiver which could either send it's result
serially or make a pin low to differentiate which transmitter was activated.
The transmitters have to be relatively cheap and only have to be activated by
one switch but the receiver must be able to tell which transmitter was activated
up to a minimum of 8 transmitters. So the receiver must not only be able to tell
which one was sending the signal but also output via Serially or it must have
adequate outputs (ie. 8) in order for the processor to know which switch was
activated.
Also if I could get a range of about 150ft.inside a building that would be
fantastic.
I have been checking wireless alarms but most don't have addressable
transmitters.
If anyone knows of a product out there that I could buy and modify I'll do it.
Ed Stevenson
Download NeoPlanet at http://www.neoplanet.com
activated.
fantastic.
transmitters.
Ed Stevenson
cost about $25 for a tx/rx/ant. You should be able to set up one
stamp to do recieving, and the others to do transmitting through a
serial line using the serout command. Using this you should be able
to preamble the serstring with which transmitter it is coming from.
-Rory.
--- In basicstamps@y..., edstevenson@v... wrote:
> Hi All,
multiple transmitters and be received by one receiver which could
either send it's result serially or make a pin low to differentiate
activated by one switch but the receiver must be able to tell which
transmitter was activated up to a minimum of 8 transmitters. So the
receiver must not only be able to tell which one was sending the
signal but also output via Serially or it must have adequate outputs
(ie. 8) in order for the processor to know which switch was activated.
would be fantastic.
addressable transmitters.
I'll do it.
> Thanks
> Ed Stevenson
