Stamp Project of the Month - RATBAS - HELP!!!!
Hi all (Al),
I've tried using RatBas but it dosn't seem to work. Perhaps I'm doing
something wrong.
I create a new xxx.bs2 file like below.
x var word
if x = 10 then
debug "hello", cr
else
debug "worked", cr
endif
I ran the program using the command
ratbas c:\xxx.bs2>c:\xxx_0.bs2
That worked and created a file called xxx_0.bs2, but the file it
created was of no size (0 bytes).
I'm not sure if it's because of something i've done or not.
I assume that this ap that you've written lets you use the
if..then..else loop which previously couldn't be used in a BS2 code
routine. Is this correct?
I'm also not sure how I send this to the stamp. If I write a
if..then..else loop in the Stamp Editor for Windows, it will not
tokinise the routine.
Please help, It would be great if I could use it.
Thanks in advance,
Simon.
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> You can run it using Start | Run or you can open an MSDOS prompt
and run it
> from there (not DOS -- but an MSDOS prompt in Windows).
> Perhaps someone will be kind enough to write a WSH shell that lets
you pick
> a file name graphically :-)
> I haven't had any bad reports so either a) it works OK, b) no one
is using
> it, c) no one could figure out how to run it :-)
> Regards,
> Al Williams
> AWC
> * Floating point math for the Stamp, PIC, SX, or any microcontroller
> http://www.al-williams.com/awce/pak1.htm
> > From: s premena [noparse][[/noparse]mailto[noparse]:p[/noparse]remzee@j...]
> > Sent: Thursday, May 03, 2001 8:20 PM
> > To: basicstamps@y...
> > Subject: [noparse][[/noparse]basicstamps] RE:Stamp Project of the Month - RATBAS
> > This program looks to be quite useful but the instructions
> > say to run it "from the command line" with two file names
> > appended - My question is: what command line? In WinDoz 98
> > I don't have a command line and in DOS the .EXE file says
> > no go in DOS. This stuff is boggling my old brain...
> > Please help me out.... thanks, premena
> > > Date: Mon, 30 Apr 2001 17:15:22 -0500
> > > From: "Al Williams" <alw@a...>
> > >The Stamp Project for May is online! No hardware this month --
> > >but some software you can use.
> > ________________________________________________________________
> > GET INTERNET ACCESS FROM JUNO!
> > Juno offers FREE or PREMIUM Internet access for less!
> > Join Juno today! For your FREE software, visit:
> > http://dl.www.juno.com/get/tagj.
> > Your use of Yahoo! Groups is subject to
something wrong.
x var word
if x = 10 then
debug "hello", cr
else
debug "worked", cr
endif
Thanks in advance,
Simon.
and run it
you pick
is using
> Regards,
> Al Williams
> AWC
(Java Developer's Kit) installed. Then you use:
java RatBas xyz.bs2 >xyz_0.bs2
The case on RatBas makes a difference. In other words, use RatBas, not
ratbas, or RATBAS.
Let me know if that works!
Al Williams
AWC
* Half-off sale in progress (ends soon): http://www.al-williams.com/awce
> From: egroups@d... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mU4pIVz_OHCvNJiuiEWWxq4t_FAwhWVTN7_SnMbdi9nSZCtsORVxKZQThlpy1Vqt1JBNRC7NucnYNf-3]egroups@d...[/url
> Sent: Tuesday, May 08, 2001 1:21 AM
> Subject: [noparse][[/noparse]basicstamps] Stamp Project of the Month - RATBAS - HELP!!!!
> Hi all (Al),
> something wrong.
> x var word
> if x = 10 then
> debug "hello", cr
> else
> debug "worked", cr
> endif
> Thanks in advance,
> Simon.
> and run it
> you pick
> is using
> > Regards,
> > Al Williams
> > AWC
No, still not working. I already have JDK installed, and downloaded
the latest JRE just to make sure.
I keep getting a Exception in thread "main"
java.lang.NoClassDefFoundError: RatBas
I've also tried the perl version (under apache, winnt 4.0) but no
success. Could you either provide the source code or some more
details about how to call the class or script please.
Sorry about all the problems...
Simon
> RatBas is a java program. You need the JRE (Java Runtime Edition)
or JDK
not
> ratbas, or RATBAS.
> Al Williams
> AWC
williams.com/awce
> > From: egroups@d... [noparse][[/noparse]mailto:egroups@d...]
HELP!!!!
> > Hi all (Al),
doing
> > something wrong.
> > x var word
> > if x = 10 then
> > debug "hello", cr
> > else
> > debug "worked", cr
> > endif
code
> > Thanks in advance,
> > Simon.
> > and run it
lets
> > you pick
one
> > is using
> > > Regards,
> > > Al Williams
> > > AWC
microcontroller
From your DOS prompt, type
echo %CLASSPATH
It should have the directory for RATBAS in it.
I'm not sure about the RATBAS.EXE that the installer makes.
Try:
java RatBas
and see if it won't come up. If not, try:
java -cp c:\ratbas\;c:\ratbas\jakarta-oro-2.0.jar RatBas (or whatever your
path is)
The Perl version requires ActivePerl or some other command line Perl. It
isn't a CGI script.
Al Williams
AWC
* 50% off sale in progress now: http://www.al-williams.com/awce
> From: egroups@d... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KFUYlSF-jmFsQo-BVTAgiN9DjXTCac9rEy6E4c_TZjgtFtGR93-QSrgnTFfe7g0N2yTHkA4vSZLvw5L6d_hm]egroups@d...[/url
> Sent: Tuesday, May 08, 2001 7:07 PM
> Subject: [noparse][[/noparse]basicstamps] Re: Stamp Project of the Month - RATBAS -
> HELP!!!!
> Hi Al,
> Simon
> or JDK
> not
> > ratbas, or RATBAS.
> > Al Williams
> > AWC
> williams.com/awce
> HELP!!!!
> > > Hi all (Al),
> doing
> > > something wrong.
> > > x var word
> > > if x = 10 then
> > > debug "hello", cr
> > > else
> > > debug "worked", cr
> > > endif
> code
> > > Thanks in advance,
> > > Simon.
> > > and run it
> lets
> > > you pick
> one
> > > is using
> > > > Regards,
> > > > Al Williams
> > > > AWC
> microcontroller
downloading it again (Sorry). If you run it with the right classpath
manually it will work, but the EXE will not work unless you reinstall.
I'm still getting the kinks out of this Java stuff. Our new NetPorter
(www.netporter.com) has a bigger, smarter install (its on a CDROM so 10M
isn't a problem there). It works OK (I just checked to be sure).
Sorry for the trouble.
Al Williams
AWC
* 50% off sale in progress! http://www.al-williams.com/awce
> From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PSB5v1l1TIExe8Di2wt2fkHlnBTiFr5QxsG9I7-aRdiy-3h8ox4rtI4CSiVJYfqkZ9bBiZ3A9OydMw]alw@a...[/url
> Sent: Tuesday, May 08, 2001 7:58 PM
> Subject: RE: [noparse][[/noparse]basicstamps] Re: Stamp Project of the Month - RATBAS -
> HELP!!!!
> Almost has to be a CLASSPATH problem.
> echo %CLASSPATH
> Try:
> java RatBas
> whatever your
> path is)
> isn't a CGI script.
> Regards,
> Al Williams
> AWC
> > From: egroups@d... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Hr-P2G3DmPmpDf4KBblajHd5gGwDN21llczQc8eNkXV8bOwZg4k1s4BuAliv_vi82DMKsgl75nKsmPcNw58]egroups@d...[/url
> > HELP!!!!
> > Hi Al,
> > Simon
> > or JDK
> > not
> > > ratbas, or RATBAS.
> > > Al Williams
> > > AWC
> > williams.com/awce
> > HELP!!!!
> > > > Hi all (Al),
> > doing
> > > > something wrong.
> > > > x var word
> > > > if x = 10 then
> > > > debug "hello", cr
> > > > else
> > > > debug "worked", cr
> > > > endif
> > code
> > > > Thanks in advance,
> > > > Simon.
> > > > and run it
> > lets
> > > > you pick
> > one
> > > > is using
> > > > > Regards,
> > > > > Al Williams
> > > > > AWC
> > microcontroller
It's working great now, thanks very much.
Simon
> Whoops... I double checked. I put the wrong installer exe in, so try
reinstall.
NetPorter
so 10M
> Al Williams
> AWC
> > From: Al Williams [noparse][[/noparse]mailto:alw@a...]
RATBAS -
> > HELP!!!!
> > echo %CLASSPATH
> > Try:
> > java RatBas
> > whatever your
> > path is)
Perl. It
> > isn't a CGI script.
> > Regards,
> > Al Williams
> > AWC
> > > HELP!!!!
> > > Hi Al,
downloaded
no
> > > Simon
Edition)
> > > or JDK
RatBas,
> > > not
> > > > ratbas, or RATBAS.
> > > > Al Williams
> > > > AWC
> > > williams.com/awce
> > > HELP!!!!
> > > > > Hi all (Al),
I'm
> > > doing
> > > > > something wrong.
> > > > > x var word
> > > > > if x = 10 then
> > > > > debug "hello", cr
> > > > > else
> > > > > debug "worked", cr
> > > > > endif
file it
BS2
> > > code
will not
> > > > > Thanks in advance,
> > > > > Simon.
prompt
> > > > > and run it
that
> > > lets
> > > > > you pick
b) no
> > > one
> > > > > is using
> > > > > > Regards,
> > > > > > Al Williams
> > > > > > AWC
> > > microcontroller
RATBAS
instructions
names
98
says
month -
