CRC — Parallax Forums
CRC
edited 2001-11-11 17:21 in General Discussion
Joe-
Here are CRC8 and CRC16 subroutines suitable for the polynomials
employed to generate Dallas 1-Wire device CRC's. Clear CRC variables
prior to use, pass successive bytes to be added to CRC in variable
"this":
crc16 VAR WORD
crc8 VAR BYTE
j VAR BYTE
addToCRC16:
for j = 1 to 8
if this.LOWBIT ^ crc16 & 1 then feedBack1_16
feedBack0_16:
crc16 = crc16 >> 1 & ~$8000: GOTO nextBit_16
feedBack1_16:
crc16 = crc16 ^ $4002 >> 1 | $8000
nextBit_16:
this = this >> 1: NEXT: RETURN
addToCRC8:
FOR j = 1 TO 8
IF this.LOWBIT ^ crc8 & 1 THEN feedBack1_8
feedBack0_8:
crc8 = crc8 >> 1 & ~$80: GOTO nextBit_8
feedBack1_8:
crc8 = crc8 ^ $18 >> 1 | $80
nextBit_8:
Steve
    edited 2001-05-08 20:11
    Does anyone have a reasonably fast/simple CRC calculation routine that will
    run on a BS2? Thanks.
    Joe
    edited 2001-05-11 23:41
    Is this the same Joe Greene I went to DeVry, Columbus with a couple years
    ago?
    Aaron Garber
    On Tue, 8 May 2001 15:11:29 -0400 "Joseph Greene" <jlgreene@i...>
    writes:
    > that will
    > Joe
    edited 2001-11-08 21:51
    Can someone explain to me what Crc is and how to implement it
    into a incomming data stream on the bs2?
    Kevin
    edited 2001-11-08 22:56
    Try these links:
    http://ozma.ssl.berkeley.edu/~dbb/crc-code.htm
    http://www.rad.com/networks/1994/err_con/crc.htm
    Leroy Hall
    > Thanks
    > Kevin
    Hi kevin
    CRC stands for cyclic redundancy cycle. Its rather complicated to
    explain.I found it in
    Basic Stamp second edition by Claus Kuhnel and Klaus Zahnert you might
    want to look it up ,it tell how to implement CRC with a stamp
    On Thu, 08 Nov 2001 21:51:43 -0000 "K Jones" <kj62@y...> writes:
    > Thanks
    > Kevin
