Digital Logic Levels...
Chris,
········Do I needto limit current between 5V logic gates - AND, NAND, OR etc. - if theoutput of one is the input of another?· Or can they be connecteddirectly?
Thanks again,
Tim
Timothy Medema
CrystaLite, Inc.
3307 CedarSt.··················(425)745-6000·· 800-666-6065
Everett, WA98201···············Fax[noparse]:([/noparse]425) 257-0232
www.crystaliteinc.com···········timm@crystaliteinc.com
The information transmitted is intended onlyfor the person or entity to whom it is addressed and may containconfidential and/or privileged material.· Any review,retransmission, dissemination or other use of, or taking of any action inreliance upon, this information by persons or entities other than theintended recipient is prohibited.· If you received this in error,please contact the sender and delete the material from anycomputer.
Thanks again,
Tim
Timothy Medema
CrystaLite, Inc.
If you'r using simple logic gates of the same family, they can, generally speaking, be connected out to in. By the time you get the signal(s) to your stamp input pin(s) you'll want to consider using pullup (or down) resistors to ensure the pin state when not active. I wouldn't worry about the current in the section you are describing, though.
I am curious as to why you would use separate gates, when you have the stamp available- are you out of pins?
:Chris
From: Timothy Medema [noparse][[/noparse]mailto:timm@crystaliteinc.com]
Sent: Monday, May 07, 2001 6:58 PM
Subject: [noparse][[/noparse]basicstamps] Digital Logic Levels...
Chris,
········Do I need to limit current between 5V logic gates - AND, NAND, OR etc. - if the output of one is the input of another?· Or can they be connected directly?
Thanks again,
Tim
Timothy Medema
CrystaLite, Inc.
3307 Cedar St.··················(425) 745-6000·· 800-666-6065
Everett, WA 98201···············Fax: (425) 257-0232
The information transmitted is intended only for the person or entity to whom it is addressed and may contain confidential and/or privileged material.· Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited.· If you received this in error, please contact the sender and delete the material from any computer.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
········No, I'mnot out of stamp pins.· I'm building several stand-alonesub-circuits that the BS2 is controlling.· By making themstand-alone, my stamp is not preoccupied most of the time.· Thankyou much for all of your help.
Tim
At 09:11 AM 5/8/2001 -0400, you wrote:
If you'r using simple logicgates of the same family, they can, generally speaking, be connected outto in. By the time you get the signal(s) to your stamp input pin(s)you'll want to consider using pullup (or down) resistors to ensure thepin state when not active. I wouldn't worry about the current in thesection you are describing, though.
I am curious as to why youwould use separate gates, when you have the stamp available- are you outof pins?
:Chris
OriginalMessage
From: Timothy Medema[noparse]/noparse][url=mailto:timm@crystaliteinc.com]mailto:timm@crystaliteinc.com[/url
Chris,
Thanks again,
Tim
Timothy Medema
CrystaLite, Inc.
Your use of Yahoo! Groups is subject to theYahoo! Terms ofService.
Timothy Medema
CrystaLite, Inc.
