Electronic Speed Control???
I have a question? Has anyone successfully used a Basic
Stamp with an Electronic Speed Control? (used with RC Cars)?
I am having an issue of accuracy with the servo running the
manual speed control. I give it a pulse one direction and an
equal amount in the opposite direction, however; it never comes
to rest in the same place. Which makes the manual speed
control useless.
If no one has used one with the Basic Stamp, does anyone
believe that you could possibly use it in conjuntion with the Basic
Stamp??
Best regards,
Karl
Email me directly at martin@d...
control useless.
Stamp??
Best regards,
Karl
power, especially if they drive gears.
Secondly, they will stop differently going different directions. This may
also have to do with weight shift and traction as far as driving a vehicle.
You may have to tinker with the code to come up with some timing to make the
car go forward and back the same distance.
> control useless.
> Stamp??
only talking about the servo not rotating back to the same
position. I have been monkeying around with the code and
cannot come up with the right timing for the servo to move the
speed control forward and backwards and end up in the same
position each time.
Karl
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> Firstly, motors will run better in one direction than the other at
full
This may
vehicle.
timing to make the
Cars)?
comes
> > control useless.
Basic
> > Stamp??
sufficient time for the servo to get to where you told it to go. In other
words, you have to send the command to the servo more times to get it to go
from 0 to 90 degrees than from 0 to 45 degrees. Some servos may take longer
to travel one direction than the other, so you may have to factor this in
also.
> Yes I am aware of this. That is not my question though. I am
> position each time.
> The ESC will work fine with the stamp. Treat it like a servo. You only need
> the control wire and ground, the power is usually an output fron the ESC
> and should not be hooked up. You will have to play with the settings if you
> are using one with reverse on it . The point at wich it quits braking and
> goes into reverse varies somewhat on the different brands of ESC's.
