32-bit counter
Volker-
Maybe Al Williams has a chip to handle this. Or you may be
interested in something I created which I call a "Pulse Machine"
(PM-1). I could run one off for you if you'd like. Here's a
summary of the (mutually exclusive) tasks it can perform:
"1. The PM-1 incorporates several pulse-related functions which may
be used to advantage with a Parallax BASIC Stamp II or other host
processor. A simple LCD interface is also provided. The PM-1
communicates with the Stamp via a single Stamp pin using half-duplex,
asynchronous 38400 baud serial transmissions. This allow the use of
simple SERIN and SEROUT commands to accomplish pulse and LCD
functions. The PM-1 is implemented in a Scenix SX18 microprocessor
and requires a 40 MHz clock source. The resolution of time-related
pulse functions is one microsecond (µsec). The timing accuracy is
determined by the clock source.
2. The following pulse generation and analysis functions are provided:
- 16-bit Pulse counter: Counts pulses occurring at up to 1 MHz rate.
High pulses appearing at the edge_1 input or low pulses appearing at
the edge_2 input are counted until receipt of any further Stamp
command. The pulse counter rolls over after 4,294,967,295 pulses. In
addition, the time elapsed while counting pulses is maintained to 1
µsec. The number of pulses and duration of pulse counting are
available for readback to the Stamp. As with all other functions, a
new command from the Stamp terminates the pulse and the new command
is executed.
- Interval pulse counter: For a designated interval (1 through
4,294,967,295 µsec), count the number of high pulses appearing at the
edge_1 input or low pulses appearing at the edge_2 input. When the
designated interval expires, the PM-1 pulls the serial line low for 50
msec to signal the Stamp. The time elapsed while counting pulses is
maintained to 1 µsec. The number of pulses and time duration are
- Report counters: The contents of the pulse and time counters are
sent to the Stamp.
- Pulse latch: The PM-1's pulse_out output is toggled upon a high
pulse occurring at the edge_1 input or low pulse occurring at the
edge_2 input. The pulse_out output remains at this level until reset
by the Stamp.
- Set pulse_out low/high: This function simply sets the pulse_out
output to the designated logic level. Its primary purpose is to
determine an initial pulse_out logic state for subsequent pulse
functions.
- One-shot: The PM-1's pulse_out output is switched to the opposite
logic level for a period of from 1 through 4,294,967,295 µsec. The
pulse begins upon receipt of the command from the Stamp.
- Edge-triggered one-shot: The one-shot pulse function occurs upon a
rising edge on the PM-1's edge_1 input, or a falling edge on the
edge_2 input.
- Pulse-triggered one-shot: The one-shot pulse function occurs upon a
high pulse on the edge_1 input or a low pulse on the edge_2 input.
- Clock generator (gated): A clock signal is generated on the
pulse_out output. The period and duty cycle are determined by
Stamp-specified values defining the high and low intervals of the
clock pulse train. Each interval may be from 1 through 4,294,967,295
µsec. The clock output is asserted only while the PM-1's active-low
gate* input is held low. Tie the gate* input low or apply the desired
logic level via software control.
- 38 KHz pulse source (gated): A 38 KHz pulse train appears at the
pulse_out output when the gate* input is low.
- 40 KHz pulse source (gated): A 40 KHz pulse train appears at the
- Pulse width modulation: A clock signal with duty cycle from 0%
through 100% is generated at the pulse_out output pin. Duty cycle is
specified as a value from 0 through 255.
- Servo pulse (gated): A clock is generated on the pulse_out output
with cycle period = 19.968 msec when the gate* input is low. The high
portion of the clock may be 1 through 2.02 msec, and is specified as a
- Clock divider: A clock signal appearing at the pulse_in input is
divided by 1 through 65,536 and appears at the pulse_out output pin.
The output clock signal has a 50% duty cycle regardless of the duty
cycle characteristic of the input clock."
I could modify the code to provide a rollover output and/or a
divide-by-2 output, but would have to give up LCD or other functions
to free up pins. Let me know if you'd like further details of
operation.
Steve
is executed.
sent to the Stamp.
by the Stamp.
functions.
edge_2 input.
operation.
Steve
I need a 32-bit counter connected to a BS2p. Of course, I can't use
all the inputs, so I need to read the count values through serial IO.
As far as I know there is no such IC available (other than one from
Dallas with a max input frequency of 1kHz, I need app. 1MHz).
Does anybody know of a 32-bit counter chip with serial out ?
Or other question, would it be possible to program a PIC to handle
this task ? My requirements are in specific :
- count up to 32 bit with input 5V, max. 1MHz (typ. 200kHz)
- reset count value to ZERO
- serial out of count value to BS2p
(- overflow output would ne nice !)
(- preload of count value not necessary !)
(- input signal/2 as extra output would be nice !)
(- rising or falling edge as counting edge doesn't matter !)
Can anybody help me here or do I have to spend the next week with a
soldering iron in my hand ?
Thanks in advance,
Volker
> ...You mentioned the 16 bit counter, counting up to 4,294,967,295
> pulses, which is 2^32 ! Which is correct ?
My apologies for the confusion. It's a 4-byte wide counter (32-bit),
0 to 4,294,967,295.
> Could you send me more information ?
I put some info on my web page:
http://home.earthlink.net/~parkiss/pm1summ.txt
http://home.earthlink.net/~parkiss/pm1bscod.txt
BTW, I leave in a few days for my semi-annual dose of dehydration,
sunburn, and blisters courtesy of the Grand Canyon backcountry. Pls
excuse any resultant delays in replies to email.
> How much is it ?
A programmed SX18 (18 pin DIP) plus Dale 40 MHz "can" oscillator by
priority mail to US addresses for $20.
Steve
thanks for your response.
- Could you give me an Email or anything to contact Al Williams ?
- LCD is not necessary, I have already one connected to the BS2p.
- You mentioned the 16 bit counter, counting up to 4,294,967,295 pulses,
If it actually is a 32-bit counter inside then this seems to be fine.
Could you send me more information ? How much is it ?
Volker
> From: S Parkis [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6OW6FsQkVykX7u6xbnXat2MTpUXWfKOJTTDc8O0zeHrcyahsvQpWZrPFac_PsHm8GklwMHsv-nMCwLXNIclF]parkiss@e...[/url
> Sent: Monday, May 07, 2001 3:57 AM
> To: Elmy; basicstamps@yahoogroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] 32-bit counter
> Volker-
> is executed.
> sent to the Stamp.
> by the Stamp.
> functions.
> edge_2 input.
> operation.
> Regards,
> Steve
I'm here. The PAK-VII acts as 8 16-bit counters. I was trying to think of a
clever way to cascade two of them. I'm fearful it would have to be in
software. Something like this (in make-believe code):
Read LowCounter
if LowCounterOld>LowCounter then update HighCounter
LowCounterOld=LowCounter
You'd have to call this more often than the counter wraps around (65K *
clock).
Also, I think you mentioned 1MHz. The PAK-VII can sample as quickly as 5uS
which is 200kHz (Nyquist limit of 100kHz). Of course, you could use the PAK
with a prescaler, but you'd lose resolution. I'm not sure if Steve's part
can run faster than that. Since you don't need 8 channels, it should be
possible to go faster.
If you need many of these, we could make a PAK-VII that had 4 32-bit
counters instead of 8 16-bit counters, but for just 1 or 2, it would
probably be too expensive to consider. Or even 1 32-bit counter operating at
a much faster rate.
Al Williams
AWC
* Connect your Stamp to the Internet?
http://www.al-williams.com/awce/netporter.htm
> From: Klocke Volker [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Z7dzBZK22B6cN-i-LXbsJrcPGrR1Gq3AHu3-bbIsptKz-C6iymFIOV69hQkvoPJSbIMg7kFjlduK8CfNdlg4]Volker.Klocke@G...[/url
> Sent: Tuesday, May 08, 2001 12:23 PM
> To: 'basicstamps@yahoogroups.com'
> Subject: RE: [noparse][[/noparse]basicstamps] 32-bit counter
> Steve,
> Thanks,
> Volker
> > From: S Parkis [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_57RqQVGLq8Afd7CjzBc2-tZvyrO5-vb-s8GmvDbQ-2sYVOcC5Z_dWM_WgM-O2XTtFBKxmQ16H6uGKaw9_U]parkiss@e...[/url
> > Volker-
> > is executed.
> > sent to the Stamp.
> > by the Stamp.
> > functions.
> > edge_2 input.
> > operation.
> > Regards,
> > Steve
>Steve,
>Thanks,
>Volker
Volker -
You can contact Al WIlliams at this web site: http://www.al-williams.com/awce
Bruce
