Pulse measurement sans Stamp
OK, the Stamp can do a good job measuring pulses with PULSIN, but are
there alternatives out there when I don't want to dedicate a stamp to
a function?
I want to set up a few functions to work of an RC receiver's PWM
servo signal, which normally varies from 1.0 - 2.0 or so ms, repeated
every 20 ms. So a device (or cascade of devices) would close a switch
if the pulse is in one range, another switch if in another range.
(And I don't want to just buy one of those multifunction devices that
are on the market).
Thx, PM
a function?
are on the market).
Thx, PM
after it works the way you want it use a Basic compiler and program a
PIC. A PIC16F872 is a 28 pin package with 22 I/O pins and can be bought
for about $3.50 plus you need a crystal if you need someone to compile
your program and write a PIC let me know.
Craig
> Message: 18
> Date: Sun, 06 May 2001 01:26:42 -0000
> From: patmat2350@a...
> Subject: Pulse measurement sans Stamp
> a function?
> are on the market).
> Thx, PM
I'm thinking there must be a simple analog/dicrete solution here...
like, maybe they convert pulse width to voltage level (= desired
position), and compare to current position (via voltage across the
position pot) with an op-amp?
The key then is conversion of pw to voltage.
Any help, anyone?
patmat
--- In basicstamps@y..., Craig Gardner <cgardner@r...> wrote:
> One way to do that would be to write the program for the basic
stamp and
a
bought
compile
> Craig
> > Message: 18
are
stamp to
> > a function?
repeated
switch
that
> > are on the market).
> > Thx, PM
