Mouse into BS2???
Aaron-
FWIW (not much), here's a BS2 version of the PIC subroutines you
referred to:
CLOCK VAR IN0 ' or whatever I/O pin
DATA VAR IN1 ' "
i VAR NIB
temp VAR BYTE
PS2_byte VAR BYTE
PS2get:
GOSUB PS2getBit ' Get/ignore the start bit
FOR i = 1 TO 8
PS2_byte = PS2_byte >> 1 + temp
NEXT
GOSUB PS2getBit ' Get/ignore parity bit
GOSUB PS2getBit ' Get/ignore stop bit
RETURN
PS2getBit:
IF CLOCK = 0 THEN PS2getBit
awaitLowClock:
IF CLOCK = 1 THEN awaitLowClock
temp = DATA << 7
RETURN
The bad news: a Stamp can't communicate (directly) with a PS/2
mouse's synchronous serial data stream because:
- You can't use discrete statements as shown above because they take
too long--the clock pulses and data levels have come and gone by the
time the Stamp realizes something is happening...
- You can't use SHIFTIN/SHIFTOUT because the mouse must supply the
clock pulses rather than using Stamp-generated clock pulses
If you're determined to use a mouse with your Stamp all the same:
- Good for you
- You can buy Al's chip
- You can build your own Stamp-optimized PS/2 interface chip--see
Jan-Mar 2000 Nuts & Volts
Steve
referred to:
DATA VAR IN1 ' "
i VAR NIB
temp VAR BYTE
PS2_byte VAR BYTE
PS2get:
FOR i = 1 TO 8
NEXT
RETURN
PS2getBit:
awaitLowClock:
temp = DATA << 7
RETURN
- Good for you
Steve
I'm wishing to be able to attach a standard ps/2 mouse into my BS2
and read the movement and buttons etc. Searching the internet I found
a bunch of links which talk about interfacing a mouse with a pic
microcontroller
(the most informative of
http://panda.cs.ndsu.nodak.edu/~achapwes/PICmicro/mouse/mouse.html)
I was wondering if anybody might be able to give me some tips as to
how I might (or if it's possible) to adjust his code for it to work
on a BS2.
Thank You
Any ideas would be greatly appreciated
Aaron Nielsen
>Hello;
>microcontroller
>on a BS2.
Hi Aaron -
You may want to look at the PAK-VI co-processor which Al WIlliams offers
here: http://www.al-williams.com/awce/pak6.htm
This is a pre-programmed PIC which can interface with a keyboard or PS/2
mouse. Al is a regular here on the list, and he'd be happy to help if you
have any questions.
>Thank You
>Aaron Nielsen
>Regards,
Bruce Bates
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
