Measuring Resistance
May someone point to me the best way to measure resistance in Ohms with
a BS2 ? Desired resolution is about 0.1 % or 1 in 1000 or less. Values
to be measured are from 2K up to 200K.
Thanks for any help
ACJacques
Thanks for any help
ACJacques
>Thanks for any help
>ACJacques
Hi Jaques,
That accuracy level (10 bits, 0.1%) is on the borderline of what can
be achieved with RCtime (or any RCtime circuit like the '555).
If you have a 10 or 12 bit A/D converter, then the resistance can be
converted to a voltage with a divider or an op-amp circuit.
-- regards,
racy Allen
mailto:tracy@e...
http://www.emesystems.com
