write help
Stamps only do one thing each time and after the previous task is
completed.
ACJacques
aconti@n... wrote:
> hi all,
> dose antone know will the BS2 do otherthings while it is writing to
> the EEprom? or will it write then when it is done then do otherthings
> write 0,255
> write 1,100
> write 2,60000.lowbyte
> write 3,60000.highbyte
> low 0
> the "low 0" would turn of the stamp(unplug it's power). would the
> stamp write to the EEprom in time befor it shut off?
> thanks
> TC
completed.
ACJacques
aconti@n... wrote:
> hi all,
> write 0,255
> write 1,100
> low 0
> thanks
> TC
write 0,255
write 1,100
low 0
thanks
TC
The write command takes about 6 milliseconds to execute. The stamp
doesn't do anything else until each write is finished, so you should
be safe with your auto-turnoff scheme.
-- Tracy
>write 0,255
>write 1,100
>low 0
